tw99
  • 34
Frequent outages since Saturday 30th for us and neighbours
I'm using a SuperHub 2 in modem mode. Since Saturday, we've been getting regular outages, several times a day and apparently always overnight.  I've got a couple of Thinkbroadband monitor charts to illustrate this.
Service is recovered when the Superhub 2 is rebooted.
We're in Area 31, Reading RG8 postcode.
Several of my neighbours who are also VM customers are having the same problem since the weekend.
(Photos edited to remove IP address)
96860c963be12d8b287a2232db45ae10-31-01-2021.png96860c963be12d8b287a2232db45ae10-01-02-2021.png96860c963be12d8b287a2232db45ae10-04-02-2021.png
First TimeLast TimePriorityError NumberDescription
04/02/2021 08:01:43 GMT04/02/2021 08:01:43 GMTError (4)68000407TOD established
Time Not EstablishedTime Not EstablishedNotice (6)84000510Downstream Locked Successfully
03/02/2021 22:05:25 GMT03/02/2021 22:05:25 GMTError (4)68000407TOD established
03/02/2021 21:35:51 GMT03/02/2021 21:35:51 GMTError (4)68000407TOD established
03/02/2021 09:16:55 GMT03/02/2021 09:16:55 GMTError (4)68000407TOD established
02/02/2021 10:05:28 GMT02/02/2021 10:05:28 GMTError (4)68000407TOD established
02/02/2021 09:04:10 GMT02/02/2021 09:04:10 GMTError (4)68000407TOD established
02/02/2021 04:40:06 GMT02/02/2021 04:40:06 GMTError (4)68000407TOD established
02/02/2021 04:39:51 GMT02/02/2021 04:39:51 GMTNotice (6)84000510Downstream Locked Successfully
02/02/2021 04:39:46 GMT02/02/2021 04:39:46 GMTCritical (3)82000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
02/02/2021 04:39:26 GMT02/02/2021 04:39:26 GMTCritical (3)82000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
02/02/2021 04:39:06 GMT02/02/2021 04:39:06 GMTCritical (3)82000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
02/02/2021 04:38:46 GMT02/02/2021 04:38:46 GMTCritical (3)82000400Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
01/02/2021 10:37:35 GMT01/02/2021 10:37:35 GMTError (4)68000407TOD established
  • 20.57K
  • 2.18K
  • 3.63K
Re: Frequent outages since Saturday 30th for us and neighbours
Post up the rest of the Hub data - for the Downsteam and Upstream channels.
Have you do a quick check that all of your coax cable connections are in nice and "finger" tight - at the Hub and wall box and also at any connectors etc. Ensure there are no “unterminated cable loose ends. Disconnect all the connections and reconnect to be sure. Also check that the internal wiring is ok with no kinking or chaffing, check that all looks good with the outside cabling and wall box.
tw99
  • 34
OK, I can do that. But when it fails, the DOCSIS layer still seems to be running fine.  If I use tcpdump on the interface of my connected router, I can see various bits of Broadcast traffic (e.g. arp requests) on the shared VM network.  However, the first hop router (i.e. the default router I get given by their DHCP)  in VM's network is unpingable.   Rebooting the smart hub is the only thing that fixes it.
Downstream  DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz)467000000411000000419000000427000000435000000443000000451000000459000000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)LockedLockedLockedLockedLockedLockedLockedLocked
Channel ID81234567
Modulation256QAM256QAM256QAM256QAM256QAM256QAM256QAM256QAM
Symbol Rate (Msym/sec)6.9520006.9520006.9520006.9520006.9520006.9520006.9520006.952000
Interleave DepthI=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)5.445.765.625.004.133.594.124.62
RxMER (dB)37.9437.3637.3637.3637.3637.0937.3637.36
Pre RS Errors6221795109311381157118711471209
Post RS Errors2778649779621007984964
1019
Upstream  US-1 US-2 US-3 US-4
Channel Type2.02.02.02.0
Channel ID1211109
Frequency (Hz)39400000462000005370000060300000
Ranging StatusSuccessSuccessSuccessSuccess
Modulation64QAM64QAM64QAM64QAM
Symbol Rate (Sym/sec)5120000512000051200005120000
Mini-Slot Size2222
Power Level (dBmV)39.7539.7541.2541.25
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts0000
T4 Timeouts0000
tw99
  • 34
Of course now it hasn't failed for 2 days, despite me not changing anything... Hopefully VM have fixed whatever it was.
