  • 7
Message 1 of 12
Frequent disconnections - all wired ethernet.
Hello. Installed at start of Dec 2019 on M200, and had no problems until the big outage in May. Since then I'm frequently getting loss of internet, but the light on the front of the Hub 3.0 does not change. I am using the Hub in modem mode, and have my own router connected. I usually notice the outage because my work laptop VPN drops, and web pages on my phone or tablet show "cannot find" and the domain of the site.
This happened again just now, so here are the stats from the Hub if someone can tell me if they are good or bad? Thanks!
1
139000000
1.2
35
256 qam
1
2
147000000
1.2
35
256 qam
2
3
155000000
1
35
256 qam
3
4
163000000
1
35
256 qam
4
5
171000000
0.9
35
256 qam
5
6
179000000
0.7
35
256 qam
6
7
187000000
0.5
35
256 qam
7
8
195000000
0.5
36
256 qam
8
9
203000000
0.2
35
256 qam
9
10
211000000
0
36
256 qam
10
11
219000000
0
36
256 qam
11
12
227000000
-0.2
36
256 qam
12
13
235000000
-0.4
36
256 qam
13
14
243000000
-0.4
36
256 qam
14
15
251000000
-0.7
36
256 qam
15
16
259000000
-0.7
36
256 qam
16
17
267000000
-0.7
36
256 qam
17
18
275000000
-0.7
36
256 qam
18
19
283000000
-0.5
36
256 qam
19
20
291000000
-0.2
36
256 qam
20
21
299000000
0.2
36
256 qam
21
22
307000000
0.4
36
256 qam
22
23
315000000
0.7
36
256 qam
23
24
323000000
0.7
36
256 qam
24
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
35
1504
27
2
Locked
35.5
19
0
3
Locked
35.5
179
0
4
Locked
35.5
937
9
5
Locked
35.5
7
0
6
Locked
35.7
1
0
7
Locked
35.7
6
0
8
Locked
36.6
5
0
9
Locked
35.7
6
0
10
Locked
36.6
5
0
11
Locked
36.3
4
0
12
Locked
36.3
4
0
13
Locked
36.3
0
0
14
Locked
36.3
0
0
15
Locked
36.3
0
0
16
Locked
36.6
0
0
17
Locked
36.3
0
0
18
Locked
36.6
0
0
19
Locked
36.3
0
0
20
Locked
36.3
5
0
21
Locked
36.6
4
0
22
Locked
36.6
6
0
23
Locked
36.6
6
0
24
Locked
36.6
0
0
  • 7
Message 2 of 12
Re: Frequent disconnections - all wired ethernet.
Part 2:
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
46200000
4.775
5120
64 qam
3
2
39400000
4.725
5120
64 qam
4
3
53700000
4.825
5120
64 qam
2
4
32600000
4.675
5120
64 qam
5
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
01/01/1970 00:02:4
critical
01/01/1970 00:01:57
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:30
critical
01/07/2020 17:45:46
notice
01/07/2020 17:44:32
critical
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/07/2020 17:43:44
critical
01/07/2020 17:42:50
notice
NOTICE ATOM is restarted as part of Self Healing Mechanism;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/07/2020 17:42:25
critical
01/07/2020 17:38:34
critical
01/07/2020 17:38:34
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/07/2020 17:37:45
critical
01/07/2020 17:37:17
notice
01/07/2020 17:37:0
critical
01/07/2020 17:36:34
Warning!
01/07/2020 17:36:34
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/07/2020 17:36:28
critical
01/07/2020 17:36:26
Warning!
01/07/2020 17:36:26
critical
01/07/2020 17:36:24
critical
01/07/2020 17:35:46
Warning!
01/07/2020 17:35:46
critical
01/07/2020 17:35:46
Warning!
01/07/2020 17:35:37
critical
  • 7
Message 3 of 12
Got disconnected trying to post this. Update from this morning, things are getting worse.
I have switched the Hub 3 to router mode as other posts advise.
02/07/2020 09:53:42Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 09:53:41criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 09:53:41Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 09:53:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 09:52:14Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 09:52:7noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 09:50:51criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 09:50:20Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 09:49:29criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 09:48:24Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 09:48:2criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 09:47:3Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 09:45:37criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 09:44:38Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 09:43:30criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 09:43:4Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 09:43:4noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 09:40:48Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 09:40:48criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 09:39:2Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 7
Message 4 of 12
Today are worse. Hub 3 in router mode, but internet not working. After a few minutes, the power light in white goes to green flashing and then green WiFi and green internet lights flashing. This does not seem to change.
Here is BQM to show disconnections:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/7328b6eb4fe33c3b5cba13debdec62c7dd...
No internet 😞
Posting this via my mobile.
  • 3.54K
  • 569
  • 1.4K
Message 5 of 12
There's not a lot to go on from the SNR and power levels, but the two network logs are appalling and show that the connection is unstable and dropping regularly.  That could be a noise or physical connection issue (even a faulty hub), or it might be a problem with VM equipment serving the area.  I've flagged the thread for VM staff to take a look and advise, but I can't say how quickly they'll be able to respond.
  • 3.84K
  • 178
  • 301
Message 6 of 12
Hi rederick,
Thanks for your posts and a very warm welcome to our Community Forums!
I'm sorry to see that you've been having issues with your broadband service.
I've looked at the stats of the hub and everything is within spec. The BQM graph, does however raise concerns.
Can you please perform a pin hole reset on the hub to see if this can help clear up this issue for us?
Kindest regards,
David_Bn
  • 7
Message 7 of 12
Hi David,
Thank you for looking at the stats, and good to know things look in spec.
I have this morning done a pin hole reset, and things have stayed connected for the last 1.5 hours, which is promising.
thanks!
  • 3.84K
  • 178
  • 301
Message 8 of 12
Thanks for letting me know
Do please continue to monitor and report back if you encounter any further issues
Kindest regards,
David_Bn
  • 7
Message 9 of 12
Hi all,
It is now Sunday 18:30 summer time. Friday night and all day Saturday was no problems.
However today, the sun is out, temperatures are higher, and I've started to get disconnected again.
The log from the Hub shows T3 and T4 time outs, and RCS Partial Service, a few times this afternoon.
No lights changing on the front of the Hub, just the white power light staying solidly lit.
05/07/2020 17:29:16 Warning! RCS Partial Service;CM-MAC=xxxx;CMTS-MAC=xxxx;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 17:27:25 critical No Ranging Response received - T3 time-out;CM-MAC=xxxx;CMTS-MAC=xxxx;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 17:26:25 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=xxxx;CMTS-MAC=xxxx;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 17:20:56 Warning! RCS Partial Service;CM-MAC=xxxx;CMTS-MAC=xxxx;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 17:20:56 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=xxxx;CMTS-MAC=xxxx;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 17:20:44 Warning! RCS Partial Service;CM-MAC=xxxx;CMTS-MAC=xxxx;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 17:20:40 critical No Ranging Response received - T3 time-out;CM-MAC=xxxx;CMTS-MAC=xxxx;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 17:20:14 Warning! RCS Partial Service;CM-MAC=xxxx;CMTS-MAC=xxxx;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 17:20:13 critical No Ranging Response received - T3 time-out;CM-MAC=xxxx;CMTS-MAC=xxxx;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 17:19:46 Warning! RCS Partial Service;CM-MAC=xxxx;CMTS-MAC=xxxx;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 17:17:16 critical No Ranging Response received - T3 time-out;CM-MAC=xxxx;CMTS-MAC=xxxx;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 17:17:16 Warning! RCS Partial Service;CM-MAC=xxxx;CMTS-MAC=xxxx;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 16:52:46 Warning! LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=xxxx;CMTS-MAC=xxxx;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 16:30:13 notice LAN login Success;CM-MAC=xxxx;CMTS-MAC=xxxx;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 14:47:12 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=xxxx;CMTS-MAC=xxxx;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 14:46:58 Warning! RCS Partial Service;CM-MAC=xxxx;CMTS-MAC=xxxx;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 14:46:55 critical No Ranging Response received - T3 time-out;CM-MAC=xxxx;CMTS-MAC=xxxx;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 14:45:35 Warning! RCS Partial Service;CM-MAC=xxxx;CMTS-MAC=xxxx;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 14:45:22 critical No Ranging Response received - T3 time-out;CM-MAC=xxxx;CMTS-MAC=xxxx;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 14:45:20 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=xxxx;CMTS-MAC=xxxx;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 14:45:20 Warning! RCS Partial Service;CM-MAC=xxxx;CMTS-MAC=xxxx;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 14:45:0 critical No Ranging Response received - T3 time-out;CM-MAC=xxxx;CMTS-MAC=xxxx;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 14:44:59 Warning! RCS Partial Service;CM-MAC=xxxx;CMTS-MAC=xxxx;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 14:44:57 critical No Ranging Response received - T3 time-out;CM-MAC=xxxx;CMTS-MAC=xxxx;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 14:44:57 Warning! RCS Partial Service;CM-MAC=xxxx;CMTS-MAC=xxxx;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 14:44:1 notice LAN login Success;CM-MAC=xxxx;CMTS-MAC=xxxx;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 14:43:28 Warning! RCS Partial Service;CM-MAC=xxxx;CMTS-MAC=xxxx;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 14:43:26 critical No Ranging Response received - T3 time-out;CM-MAC=xxxx;CMTS-MAC=xxxx;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 14:43:26 Warning! RCS Partial Service;CM-MAC=xxxx;CMTS-MAC=xxxx;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 14:43:25 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=xxxx;CMTS-MAC=xxxx;CM-QOS=1.1;CM-VER=3.0;
Whilst writing this post, it went again, have updated log lines above, had to copy/paste to Notepad.
iPad reports "No internet connection" on the Hub WiFi and my desktop PC connected via ethernet cable to Port 1 on the Hub showed "link disconnected".
The hub rebooted itself, green light flashing, then eventually when white light appears, I get internet back.
Any ideas?
This afternoon's TBB BQM snapshot:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/032aa42d77d21072c8a6ac66371fc37b7e3437cd-05-07-2020
Thanks!
  • 7
Message 10 of 12
Signal levels
1483000000-0.737256 qam30
2187000000-235256 qam7
3195000000-235256 qam8
4203000000-235256 qam9
5211000000-235256 qam10
6219000000-2.235256 qam11
7227000000-235256 qam12
8235000000-235256 qam13
9243000000-236256 qam14
10251000000-2.236256 qam15
11259000000-235256 qam16
12267000000-236256 qam17
13275000000-1.936256 qam18
14283000000-1.536256 qam19
15291000000-1.236256 qam20
16299000000-0.736256 qam21
17307000000-0.436256 qam22
18315000000036256 qam23
19323000000036256 qam24
20443000000037256 qam25
21451000000-0.237256 qam26
22459000000-0.437256 qam27
23467000000-0.537256 qam28
24475000000-0.537256 qam29
1Locked37.3279301
2Locked35.523622021
3Locked35.7790814
4Locked35.7369614
5Locked35.7252596
6Locked35.7287575
7Locked35.7377712
8Locked35.7387541
9Locked36.3278601
10Locked36.6261491
11Locked35.7283514
12Locked36.3524444
13Locked36.3281415
14Locked36.3237590
15Locked36.6247417
16Locked36.3286431
17Locked36.3246443
18Locked36.6250343
19Locked36.6249354
20Locked37.3252328
21Locked37.6297310
22Locked37.6278303
23Locked37.3306314
24Locked37.6258333
1394000004.7512064 qam4
2462000004.75512064 qam3
3537000004.825512064 qam2
4603000004.875512064 qam1
3ATDMA0000
4ATDMA0000
Network LogTime Priority Description
05/07/2020 17:37:0Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 17:35:21criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 17:34:34criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 17:30:30Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 17:30:28criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 17:29:16Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 17:27:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 17:26:25criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 17:20:56Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 17:20:56criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 17:20:44Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 17:20:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 17:20:14Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 17:20:13criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 17:19:46Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 17:17:16criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 17:17:16Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 16:52:46Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 16:30:13noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 14:47:12criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
