26-08-2022 19:17 - edited 26-08-2022 19:46
Hi all,
Over the last few weeks, i have been getting frequent drop outs at random times every day. They keep on disconnecting me from games and stops streaming of my family members. I have restarted the router (Hub 5 - Gig1) and tried it in both modem and router mode. The issues persist in both states. I currently have it in router mode with 2g and 5g off, hooked up with a velop mesh network.
I have been reading other posts, and started a BQM and logged into the hub to get the relevant downstream and upstream data that has been requested. I should state though, that when it comes to the Network Log, it never loads for me. It just keeps on doing the spinning, loading animation, but never shows any data. If this changes, i will also post the network log data.
The disconnections happen with both wifi and ethernet. I have checked to make sure all cables are secure and connected properly.
BQM Link:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/19d13997b50f2767d4d5d846367d793f43801cd4-26-08-2022
Thank you
on 26-08-2022 19:18
1 | 427000000 | 5.8 | 40 | QAM 256 | 37 |
2 | 211000000 | 9.2 | 40 | QAM 256 | 10 |
3 | 219000000 | 9.3 | 40 | QAM 256 | 11 |
4 | 227000000 | 9.3 | 39 | QAM 256 | 12 |
5 | 235000000 | 9.1 | 40 | QAM 256 | 13 |
6 | 243000000 | 8.9 | 40 | QAM 256 | 14 |
7 | 251000000 | 8.9 | 40 | QAM 256 | 15 |
8 | 259000000 | 8.9 | 40 | QAM 256 | 16 |
9 | 267000000 | 8.9 | 40 | QAM 256 | 17 |
10 | 275000000 | 8.8 | 40 | QAM 256 | 18 |
11 | 283000000 | 8.7 | 40 | QAM 256 | 19 |
12 | 291000000 | 8.7 | 40 | QAM 256 | 20 |
13 | 299000000 | 8.6 | 40 | QAM 256 | 21 |
14 | 307000000 | 8.6 | 40 | QAM 256 | 22 |
15 | 315000000 | 8.4 | 40 | QAM 256 | 23 |
16 | 323000000 | 8.3 | 40 | QAM 256 | 24 |
17 | 331000000 | 8.1 | 40 | QAM 256 | 25 |
18 | 339000000 | 7.9 | 40 | QAM 256 | 26 |
19 | 347000000 | 7.7 | 40 | QAM 256 | 27 |
20 | 355000000 | 7.4 | 40 | QAM 256 | 28 |
21 | 363000000 | 7.3 | 40 | QAM 256 | 29 |
22 | 371000000 | 7.2 | 40 | QAM 256 | 30 |
23 | 379000000 | 7 | 40 | QAM 256 | 31 |
24 | 387000000 | 6.7 | 40 | QAM 256 | 32 |
25 | 395000000 | 6.7 | 40 | QAM 256 | 33 |
26 | 403000000 | 6.5 | 40 | QAM 256 | 34 |
27 | 411000000 | 6.3 | 40 | QAM 256 | 35 |
28 | 419000000 | 6 | 40 | QAM 256 | 36 |
29 | 435000000 | 5.7 | 40 | QAM 256 | 38 |
30 | 443000000 | 5.3 | 40 | QAM 256 | 39 |
31 | 451000000 | 5.2 | 40 | QAM 256 | 40 |
1 | Locked | 40 | 2642 | 1901 |
2 | Locked | 40 | 804791 | 5653 |
3 | Locked | 40 | 488806 | 3174 |
4 | Locked | 39 | 1148200 | 27780 |
5 | Locked | 40 | 794374 | 35674 |
6 | Locked | 40 | 526426 | 11683 |
7 | Locked | 40 | 715744 | 2979 |
8 | Locked | 40 | 351239 | 222 |
9 | Locked | 40 | 214091 | 113 |
10 | Locked | 40 | 546389 | 164 |
11 | Locked | 40 | 787504 | 67695 |
12 | Locked | 40 | 452964 | 55437 |
13 | Locked | 40 | 230657 | 40191 |
14 | Locked | 40 | 129692 | 3206 |
15 | Locked | 40 | 71225 | 15 |
16 | Locked | 40 | 42432 | 13 |
17 | Locked | 40 | 11727 | 54 |
18 | Locked | 40 | 53956 | 60 |
19 | Locked | 40 | 30178 | 53 |
20 | Locked | 40 | 14742 | 23 |
21 | Locked | 40 | 18529 | 11 |
22 | Locked | 40 | 5769 | 55 |
23 | Locked | 40 | 3295 | 20 |
24 | Locked | 40 | 9292 | 533 |
25 | Locked | 40 | 7916 | 10 |
26 | Locked | 40 | 9618 | 23 |
27 | Locked | 40 | 12146 | 0 |
28 | Locked | 40 | 6628 | 12 |
29 | Locked | 40 | 1511 | 1881 |
30 | Locked | 40 | 448 | 0 |
31 | Locked | 40 | 1147 | 1879 |
on 26-08-2022 19:18
0 | 49600000 | 36.5 | 5120 | QAM 64 | 1 |
1 | 43100000 | 36 | 5120 | QAM 64 | 2 |
2 | 36600000 | 35 | 5120 | QAM 64 | 3 |
3 | 30100000 | 35 | 5120 | QAM 64 | 4 |
4 | 23600000 | 34.3 | 5120 | QAM 64 | 5 |
0 | ATDMA | 0 | 0 | 0 | 0 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 1 | 0 |
on 26-08-2022 19:31
26-08-2022 19:31:24 | critical | TFTP Request Retries exceeded, CM unable to register |
26-08-2022 19:31:24 | critical | TFTP failed - Request sent - No Response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-08-2022 19:30:50 | critical | DHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-08-2022 19:30:27 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-08-2022 19:30:25 | critical | TFTP Request Retries exceeded, CM unable to register |
26-08-2022 19:30:25 | critical | TFTP failed - Request sent - No Response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-08-2022 19:29:31 | notice | CM-STATUS message sent. Event Type Code: 3; Chan ID: N/A; DSID: Q; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-08-2022 19:29:12 | warning | Unicast DSID PSN startup error |
26-08-2022 19:29:08 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-08-2022 19:29:08 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-08-2022 19:29:04 | notice | REGISTRATION COMPLETE - Waiting for Operational status |
26-08-2022 19:28:58 | warning | Dynamic Range Window violation |
26-08-2022 19:28:58 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-08-2022 19:28:58 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-08-2022 19:28:58 | warning | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-08-2022 19:28:52 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-08-2022 19:28:50 | warning | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-08-2022 19:28:48 | notice | Honoring MDD; IP provisioning mode = IPv4 |
26-08-2022 19:28:48 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-08-2022 19:28:39 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-08-2022 19:28:31 | critical | Cable Modem Reboot due to power button reset |
26-08-2022 19:28:27 | critical | Cable Modem Reboot due to master console reset |
26-08-2022 04:40:18 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-08-2022 04:40:10 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-08-2022 04:40:06 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
on 26-08-2022 22:10
26-08-2022 21:37:36 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Around the time these warnings show, i started having some packet loss. Is it something to do with high power?
on 27-08-2022 11:44
Large amount of Pre & Post RS errors, but as these are accumulative since the hub was last power cycled could you please turn off the hub and then on after 1 minute. After 2 hours please post a new full set of stats and we can then see if this is the problem.
Also worth checking with Area faults on 0800 561 0061 If you have a VM landline 150 this goes down to post code level.
29-08-2022 20:34 - edited 29-08-2022 20:45
Hi, thank you for the response. Apologies for the slow response, I was away over the weekend. As of today though, i am still having issues.
Here is a new BQM, with some definite packet loss (the one around 6pm was me resetting router, the big one after, im not sure, the net just died..)
https://www.thinkbroadband.com/broadband/monitoring/quality/share/24df95d20ea63efac452a6122e61e016abeb37a4-29-08-2022
29-08-2022 18:21:25 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2022 17:59:01 | critical | TFTP failed - Request sent - No Response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2022 17:59:01 | critical | TFTP Request Retries exceeded, CM unable to register |
29-08-2022 17:58:27 | critical | DHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2022 17:58:04 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2022 17:58:02 | critical | TFTP Request Retries exceeded, CM unable to register |
29-08-2022 17:58:02 | critical | TFTP failed - Request sent - No Response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2022 17:57:17 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2022 17:57:15 | critical | TFTP Request Retries exceeded, CM unable to register |
29-08-2022 17:57:15 | critical | TFTP failed - Request sent - No Response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2022 17:56:47 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2022 17:56:47 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2022 17:56:44 | notice | REGISTRATION COMPLETE - Waiting for Operational status |
29-08-2022 17:56:37 | warning | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2022 17:56:37 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2022 17:56:37 | warning | Dynamic Range Window violation |
29-08-2022 17:56:31 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2022 17:56:29 | warning | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2022 17:56:27 | notice | Honoring MDD; IP provisioning mode = IPv4 |
29-08-2022 17:56:25 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2022 17:56:19 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2022 17:56:16 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2022 17:56:08 | critical | Cable Modem Reboot due to power button reset |
29-08-2022 17:56:04 | critical | Cable Modem Reboot due to master console reset |
24-08-2022 20:26:38 | critical | 16 consecutive T3 timeouts while trying to range on upstream channel 8;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
24-08-2022 20:26:38 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
on 29-08-2022 20:36
1 | 427000000 | 5.9 | 40 | QAM 256 | 37 |
2 | 211000000 | 9.1 | 39 | QAM 256 | 10 |
3 | 219000000 | 9.2 | 39 | QAM 256 | 11 |
4 | 227000000 | 9.1 | 39 | QAM 256 | 12 |
5 | 235000000 | 9.1 | 39 | QAM 256 | 13 |
6 | 243000000 | 8.8 | 39 | QAM 256 | 14 |
7 | 251000000 | 8.6 | 40 | QAM 256 | 15 |
8 | 259000000 | 8.8 | 40 | QAM 256 | 16 |
9 | 267000000 | 8.8 | 40 | QAM 256 | 17 |
10 | 275000000 | 8.7 | 40 | QAM 256 | 18 |
12 | 291000000 | 8.6 | 40 | QAM 256 | 20 |
18 | 339000000 | 7.8 | 40 | QAM 256 | 26 |
22 | 371000000 | 7.3 | 40 | QAM 256 | 30 |
24 | 387000000 | 6.8 | 40 | QAM 256 | 32 |
25 | 395000000 | 6.8 | 40 | QAM 256 | 33 |
28 | 419000000 | 6.1 | 40 | QAM 256 | 36 |
29 | 435000000 | 5.7 | 39 | QAM 256 | 38 |
30 | 443000000 | 5.4 | 40 | QAM 256 | 39 |
31 | 451000000 | 5.2 | 39 | QAM 256 | 40 |
1 | Locked | 40 | 36 | 0 |
2 | Locked | 39 | 73396 | 311 |
3 | Locked | 39 | 39743 | 141 |
4 | Locked | 39 | 133451 | 202 |
5 | Locked | 39 | 76668 | 1733 |
6 | Locked | 39 | 44028 | 139 |
7 | Locked | 40 | 50152 | 70 |
8 | Locked | 40 | 21653 | 67 |
9 | Locked | 40 | 12094 | 60 |
10 | Locked | 40 | 29875 | 30 |
11 | Locked | 40 | 95017 | 191 |
12 | Locked | 40 | 47707 | 3028 |
13 | Locked | 40 | 24253 | 1842 |
14 | Locked | 40 | 11024 | 1 |
15 | Locked | 40 | 2649 | 0 |
16 | Locked | 40 | 1706 | 0 |
17 | Locked | 40 | 422 | 0 |
18 | Locked | 40 | 2064 | 0 |
19 | Locked | 40 | 1291 | 0 |
20 | Locked | 40 | 740 | 0 |
21 | Locked | 40 | 749 | 0 |
22 | Locked | 40 | 156 | 0 |
23 | Locked | 40 | 107 | 0 |
24 | Locked | 40 | 204 | 0 |
25 | Locked | 40 | 110 | 0 |
26 | Locked | 40 | 173 | 0 |
27 | Locked | 40 | 264 | 0 |
28 | Locked | 40 | 127 | 0 |
29 | Locked | 39 | 23 | 0 |
30 | Locked | 40 | 8 | 0 |
31 | Locked | 39 | 16 | 0 |
on 29-08-2022 20:36
0 | 49600000 | 36.8 | 5120 | QAM 64 | 1 |
1 | 43100000 | 35.8 | 5120 | QAM 64 | 2 |
2 | 36600000 | 35.3 | 5120 | QAM 64 | 3 |
3 | 30100000 | 34.8 | 5120 | QAM 64 | 4 |
4 | 23600000 | 34.8 | 5120 | QAM 64 | 5 |
4 | ATDMA | 0 | 0 | 0 | 0 |
30-08-2022 20:19 - edited 30-08-2022 20:23
Here we go again... Can't stream, can hardly browse the net. Packet loss starting at around 8PM.. Seems community fibre is in my area soon. It's looking increadingly appealing.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/ab363ed3ee5686305a6c17c5036597ad41900327
Network Log from today:
30-08-2022 19:35:38 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
30-08-2022 19:26:19 | warning | Dynamic Range Window violation |
30-08-2022 19:26:19 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
30-08-2022 12:58:21 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
30-08-2022 12:58:21 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
30-08-2022 12:29:00 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
30-08-2022 09:58:08 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
30-08-2022 09:58:08 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
30-08-2022 03:52:10 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
30-08-2022 03:00:55 | warning | Dynamic Range Window violation |
30-08-2022 03:00:55 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
