on 15-06-2023 11:27
There was a problem with the internet in my area a few weeks ago which resolved [no internet for multiple days], and ever since then we've had unusually high ping and packet loss. There are also a few disconnects. But the ping will spike every 2 hours every single day with packet loss occurring throughout the day. During those times i noticed even the download speed will decrease from 350 mbps to 150. This packet loss and ping issue has never happened before until the virgin media technicians came to our area and fixed the previous issue. Now its an ongoing issue, would appreciate some help or a technician who can take a look.
Here is the BQM graphs just from the last 3 days.
Ive tried to restart the hub a week ago but it hasnt fixed anything, even using a pin reset. I've switched the hub off and unplugged it from the mains supply for five minutes and checked all cables but it hasnt fixed anything.
1 | 283000000 | 3.7 | 40 | 256 qam | 19 |
2 | 203000000 | 4 | 40 | 256 qam | 9 |
3 | 211000000 | 3.7 | 40 | 256 qam | 10 |
4 | 219000000 | 3.4 | 40 | 256 qam | 11 |
5 | 227000000 | 3.5 | 40 | 256 qam | 12 |
6 | 235000000 | 3.9 | 40 | 256 qam | 13 |
7 | 243000000 | 3.5 | 40 | 256 qam | 14 |
8 | 251000000 | 3.2 | 40 | 256 qam | 15 |
9 | 259000000 | 3.4 | 40 | 256 qam | 16 |
10 | 267000000 | 3.5 | 40 | 256 qam | 17 |
11 | 275000000 | 3 | 40 | 256 qam | 18 |
12 | 291000000 | 3.7 | 40 | 256 qam | 20 |
13 | 299000000 | 3.9 | 40 | 256 qam | 21 |
14 | 307000000 | 3.9 | 40 | 256 qam | 22 |
15 | 315000000 | 4 | 40 | 256 qam | 23 |
16 | 323000000 | 3.5 | 40 | 256 qam | 24 |
17 | 331000000 | 3.7 | 40 | 256 qam | 25 |
18 | 339000000 | 3.7 | 40 | 256 qam | 26 |
19 | 347000000 | 3.5 | 40 | 256 qam | 27 |
20 | 355000000 | 3.7 | 40 | 256 qam | 28 |
21 | 363000000 | 3.7 | 40 | 256 qam | 29 |
22 | 371000000 | 3.5 | 40 | 256 qam | 30 |
23 | 379000000 | 3.5 | 40 | 256 qam | 31 |
24 | 387000000 | 3.5 | 40 | 256 qam | 32 |
1 | Locked | 40.3 | 107973 | 6266 |
2 | Locked | 40.9 | 484939 | 21717 |
3 | Locked | 40.9 | 439818 | 20481 |
4 | Locked | 40.3 | 389175 | 19376 |
5 | Locked | 40.3 | 325988 | 17829 |
6 | Locked | 40.9 | 276405 | 16207 |
7 | Locked | 40.3 | 226730 | 14106 |
8 | Locked | 40.9 | 196510 | 12508 |
9 | Locked | 40.9 | 170881 | 11430 |
10 | Locked | 40.9 | 159680 | 10545 |
11 | Locked | 40.3 | 128472 | 8150 |
12 | Locked | 40.3 | 91032 | 4858 |
13 | Locked | 40.3 | 75821 | 3893 |
14 | Locked | 40.9 | 61625 | 3105 |
15 | Locked | 40.9 | 49245 | 2257 |
16 | Locked | 40.3 | 38279 | 1370 |
17 | Locked | 40.9 | 36288 | 1119 |
18 | Locked | 40.3 | 31661 | 991 |
19 | Locked | 40.9 | 24000 | 724 |
20 | Locked | 40.3 | 23362 | 793 |
21 | Locked | 40.9 | 22077 | 842 |
22 | Locked | 40.9 | 20253 | 712 |
23 | Locked | 40.9 | 20992 | 519 |
24 | Locked | 40.3 | 17608 | 307 |
1 | 43100000 | 42.5 | 5120 | 64 qam | 10 |
2 | 23600000 | 43 | 5120 | 64 qam | 13 |
3 | 30100000 | 42 | 5120 | 64 qam | 12 |
4 | 36600000 | 43 | 5120 | 64 qam | 11 |
5 | 49600000 | 43.5 | 5120 | 64 qam | 9 |
on 15-06-2023 12:11
Is it the Hub 3 by any chance ?I've had dropouts for over a week now daily . And I'm still stuck in a contact paying for nothing . They do compensation but that's not what I want . I want them to fix the problem but they can't. I had a technician come Tuesday he replaced the hub for another Hub3 and it's still the same. I literally had better connectivity on a mobile data hub and I'm considering doing that . Anyway good luck you'll need it .
on 15-06-2023 13:00
I am experiencing the same. Also Hub3. based in Reading RG6.
on 15-06-2023 13:27
Mine started working again the minute after my first message above. So either virgin saw my message and did something or it might be because i went outside and pulled the black wire going into my home . I do know there's a slight cut in this wire from something or someone but the technician just covered it up with a plastic box when he came on Tuesday. Maybe the heat is expanding where the slight cut is causing disconnection . If not it's definitely got to be the Hub 3s in general or a problem with the box terminal down the street or problems back at Virgin medias side . Everything else has been tried and tested other than those. And I bet on your account it says everything's good like mine . I ran the test kit it either says the equipment isn't connected properly and either there's a signal problem to what pops up . I know it's connected now but I know it won't last before it could out . I've also noticed it happens early in the morning without fail and weirdly when it reaches 20 to 23 degrees C .
on 15-06-2023 19:34
Yes i do have a Hub 3, this isnt just a problem for me as some of my friends also have experienced the same thing. I dont need the router replaced as this has already been done twice for previous issues and it didnt fix a thing.
Anyways here are the BQM images for the past 3 days:
on 16-06-2023 13:56
Same thing happening today
on 16-06-2023 14:02
I have the 1GB Hub 5. High pings and drop outs constantly. Good luck trying to get this sorted as Virgin are aware of the issues, due to all the people asking the same question, but they really don't have a fix. I am trying to cancel right now, due to unfit service, even in contract. getting someone to help at virgin media is extremely hard .
on 17-06-2023 02:04
More disconnects and packet loss, this is horrible
on 19-06-2023 15:55
Hey @AyadMH,
Welcome back to the Community Forums and thanks for the post.
Sorry to hear you are having this issue, for me to look into this deeper for you, I will need to invite you in for a quick private message so that I can confirm some information.
If you have not used this feature before, you can access it via the envelope at the top of your screen.
Speak to you soon. Joe
on 19-07-2023 12:49
Just to let you know im still experiencing the same issue only its gotten worse. Now internet speeds are dropping massively. Im supposed to be getting 350 mbps and look what i get
