sumitapata
  • 6
Forcing a device to connect to nearest pod
Hi. I have got a hub4 and 2 wifi pods. I have a ring outdoor camera outside the house and in the room just inside there’s one of the pods. But when I check using the virgin connect app the camera always shows as connected to the main hub which 2 rooms away. The camera is hence complaining of low wifi signals
Is there any way I can make the ring cam force connect to the nearest pod?
Tags (3)
  • 6.81K
  • 592
  • 1.78K
Re: Forcing a device to connect to nearest pod
I’m not sure if the “Intelligent WiFi” is intelligent enough to do this…..
