Robasmith
  • 18
Message 1 of 29
Fluctuating internet quality
Hi, hoping someone can help!
I've been having some issues with the quality of my internet connection.
Gig1 1000mbps internet using Superhub 4 as modem and a Asus RT-AX864U as the router.
The speeds are fine and while the ping could be better it is still consistently around 20ms.
However I am finding that the connection dips very often. If I am watching live videos on YouTube the quality drops to 144p or 240p on a regular basis and I have to auto select a higher quality. Buffering is an issue too. I have also noticed lagging issues when gaming via PS4 using a wired connection.
I have tried adjusting the QoS on the Asus router which just made the issue worse.
I have set up a BQM (attached) which seems to show no issues so I'm really unsure what could be causing the problems?
lotharmat
  • 950
  • 70
  • 143
Well-informed
Message 2 of 29
Re: Fluctuating internet quality
Can you post your Hub status and logs?
Someone should be spot if there is a problem
Navigate to http://192.168.0.1 (or http://192.168.100.1 - if in modem mode)
Don't log in!
Click on 'router status'
Copy/paste the data from each of the tabs. The forum software will remove the MAC addresses for you (you may need to click the 'post' button again).
  • 15.94K
  • 691
  • 1.56K
Message 3 of 29
Likely a CDN problem for your area.
Robasmith
  • 18
Message 4 of 29
Copy and pasting this has made it look a bit of a mess....
Cable Modem StatusItemStatusCommentsCable Modem Status
Online
DOCSIS 3.1
Primary downstream channel
Locked
SC-QAM
Channel OverviewDownstreamUpstreamDOCSIS 3.0 channels
31
4
DOCSIS 3.1 channels
1
0
3.0 Downstream channelsChannelFrequency (Hz)Power (dBmV)SNR (dB)ModulationChannel ID11390000001.20000140.366287QAM256121470000001.29999940.366287QAM256231550000001.40000240.946209QAM256341630000001.50000040.366287QAM256451710000001.20000140.366287QAM256561790000000.70000140.946209QAM256671870000000.29999940.366287QAM256781950000000.09999840.946209QAM25689203000000-0.29999940.946209QAM256910211000000-0.59999840.366287QAM2561011219000000-0.79999940.366287QAM2561112227000000-1.09999840.946209QAM2561213235000000-1.40000240.366287QAM2561314243000000-1.79999940.366287QAM2561415251000000-1.90000240.366287QAM2561516259000000-1.90000240.366287QAM2561617267000000-1.50000040.366287QAM2561718275000000-1.20000138.983261QAM2561819283000000-1.40000240.366287QAM2561920291000000-1.50000040.366287QAM2562021299000000-2.00000038.983261QAM2562122307000000-2.59999838.983261QAM2562223315000000-2.90000238.983261QAM2562324323000000-2.70000138.605377QAM2562425411000000-3.29999938.983261QAM2562526419000000-4.00000038.605377QAM2562627427000000-4.29999938.983261QAM2562728435000000-4.50000038.983261QAM2562829443000000-4.20000138.983261QAM2562930451000000-4.70000138.983261QAM2563031459000000-5.09999838.983261QAM25631
3.0 Downstream channelsChannelLock StatusRxMER (dB)Pre RS ErrorsPost RS Errors1Locked40.366287002Locked40.366287003Locked40.946209004Locked40.366287005Locked40.366287006Locked40.946209007Locked40.366287008Locked40.946209009Locked40.9462090010Locked40.3662870011Locked40.3662870012Locked40.9462090013Locked40.3662870014Locked40.3662870015Locked40.3662870016Locked40.3662870017Locked40.3662870018Locked38.9832610019Locked40.3662870020Locked40.3662870021Locked38.9832610022Locked38.9832610023Locked38.9832610024Locked38.6053770025Locked38.9832610026Locked38.6053770027Locked38.9832610028Locked38.9832610029Locked38.9832610030Locked38.9832610031Locked38.98326100
3.0 Upstream channelsChannelFrequency (Hz)Power (dBmV)Symbol Rate (ksps)ModulationChannel ID13260000044.5205995120 KSym/sec64QAM322580000045.5205995120 KSym/sec64QAM433940000043.5205995120 KSym/sec64QAM244620000043.5205995120 KSym/sec64QAM1
3.0 Upstream channelsChannelChannel TypeT1 TimeoutsT2 TimeoutsT3 TimeoutsT4 Timeouts1US_TYPE_STDMA00102US_TYPE_STDMA00103US_TYPE_STDMA00004US_TYPE_STDMA0000
General ConfigurationNetwork access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
cmreg-vmdg640-bbt076-b.cm
Primary Downstream Service FlowSFID
704814
Max Traffic Rate
1200000450
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service FlowSFID
704813
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
42600
Scheduling Type
  • Network LogTimePriorityDescriptionThu Jan 1 00:01:23 19704Missing Mandatory MDD TLV on primary DS Channel;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;Thu Jan 1 00:01:45 19703No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;Mon Mar 22 13:14:30 20215MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;Mon Mar 22 13:17:35 20216SW Download INIT - Via Config file cmreg-vmdg640-bbt076-b.cmMon Mar 22 13:18:47 20216SW download Successful - Via Config fileMon Mar 22 13:21:17 20215MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;Mon Mar 22 13:47:41 20214DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;Thu Jan 1 00:01:19 19703No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;Mon Mar 22 14:06:32 20215MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;Mon Mar 22 14:06:43 20215RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;Mon Mar 22 14:07:07 20216CM-STATUS message sent. Event Type Code: 5; Chan ID: 41; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;Mon Mar 22 14:28:16 20215MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;Mon Mar 22 15:06:12 20214DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;Wed Mar 24 16:32:07 20215MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;Thu Jan 1 00:01:20 19703No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;Fri Mar 26 10:18:10 20215MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;Fri Mar 26 10:18:20 20215RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;Fri Mar 26 10:18:30 20216CM-STATUS message sent. Event Type Code: 4; Chan ID: 41; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;Thu Jan 1 00:01:21 19703No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;Fri Mar 26 10:30:56 20215MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;Fri Mar 26 21:29:33 20213No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;Sat Mar 27 21:42:38 20215MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;Tue Mar 30 12:54:18 20214DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;Thu Apr 1 09:00:19 20213No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;Fri Apr 2 18:06:06 20214DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
bestEffort
Robasmith
  • 18
Message 5 of 29
I've posted them above.
Thanks.
Robasmith
  • 18
Message 6 of 29
I haven't received a reply about this yet so I am assuming it's because the copy and pasting was difficult to read. I have attached screenshots. There are also several errors showing on the network log but it won't let me upload these because it shows my MAC address.
Thanks in advance. Screenshot1.pngScreenshot2.pngScreenshot3.pngScreenshot4.pngScreenshot5.pngScreenshot6.pngScreenshot7.pngScreenshot8.pngScreenshot9.pngScreenshot10.pngScreenshot11.png
lotharmat
  • 950
  • 70
  • 143
Well-informed
Message 7 of 29
Apart from a couple of T3 timeouts - the stats look, to me, OK!
Hopefully VM Staff will be along shortly to have a look and see what's occurring!
Robasmith
  • 18
Message 8 of 29
Thanks Iotharmat,
On the network report it says several times that "no ranging response received". Could this be relevant?
Tom_F
  • 3.08K
  • 182
  • 386
Message 9 of 29
Hi @Robasmith, sorry to hear these issues are ongoing.
When taking a further look into this from here I can see the hub is out of spec and will require the attention of an engineer. I've booked the soonest available one - you can find confirmation via your online account (virg.in/myVM) and reschedule from there if needed.
Let us know how that goes or if there's anything else we can help with.
Tom
Robasmith
  • 18
Message 10 of 29
@Tom_F That's fantastic thank you so much. I'm off work tomorrow so the date works perfectly.
Fingers crossed it results in an improvement.
Thanks again.
