Ashleigh1207
Flashing lights on hub 3
My WiFi was turned off unexpectedly last night as we were having electrics done. The hub has since turned back on, but I have no Internet connection.
The arrows are flashing and the power light is a solid green, the power light then starts flashing and the arrows turn off.
I have tried the reset button on the back but it hasn't worked. I logged on online and it said it was update, but this has been like it for a whole night.
Any advice?
lotharmat
  • 2.54K
  • 188
  • 462
Trouble shooter
Re: Flashing lights on hub 3
Resets can be a bit finickety!
follow this procedure:
Make sure you can read all the default passwords on the base of the Hub before you do this
Unplug all ethernet cables
With the power on and the co-ax connected; press and hold the reset switch with a paperclip or sim removal tool for at least 60 seconds.
Allow 10 minutes to reboot, reset and stabilise
Ayisha_B
  • 1.46K
  • 50
  • 137
Hi @Ashleigh1207,
Welcome to our Community Forums and thanks for posting.
I do apologise for our delayed response. Did the advice given by @lotharmat help?
Let me know if you are still having issues and I will be happy to look into this further 🙂
Ayisha_B
