Flashing green light on hub
I've just disconnected my hub as moving furniture around. Tried to connect only half hour later the hub is showing the green wifi sign, flashing green light below and intermittently, the two arrows are flashing. It's been like this for 3 hours. Tried switching on and off, disconnecting and reconnecting wires. And checked internet status
  • 15.74K
  • 1.65K
  • 2.69K
Re: Flashing green light on hub
Does this help interpret whats going on (I dont have a Hub3 but assume you have)?
https://www.virginmedia.com/help/virgin-media-what-do-the-lights-on-your-hub-mean
Yes, it's a Hub3. I've tried the various suggestions on the links already - with no success. Tried the connection in the area which says no problem too. Was trying to avoid calling up as it's very busy at the moment.
  • 15.42K
  • 1.72K
  • 3.54K
Sounds like something has come loose.
Check the coax connections both at the back of the hub & at the wall box or splitter to make sure they are in tight.
Virgin BB TV Landline. Freeview/Freesat HD, Virgin Mobile, Tesco Mobile. Cable customer since 1993
