  • 12
Message 1 of 5
Flashing Green WiFi light
For the last few days every 24 hours or so my hub WiFi Green light starts to flash, and will not go away unless i reboot. I even done a hard reset.
After about 24 hours or so, the green light starts to flash again, why?
Anybody help?
  • 2.58K
  • 391
  • 529
Trouble shooter
Message 2 of 5
Re: Flashing Green WiFi light
Hi Driver107,
This is a known fault with the hub3.
Please try depressing WAP button for 20 seconds - that normally resolves the issue, although you could perform a pinhole reset.
Dave
  • 12
Message 3 of 5
Hi Dave
Thanks for your response but still the light flashes after 24 hours even after doing what you suggested.
I rang Virgin and what a complete waste of time, spoke to a useless operator who didn't know anything about their systems.
If anyone else can help I would be appreciated.
  • 2.04K
  • 152
  • 465
Problem sorter
Message 4 of 5
It’s a known fault which VM are extremely slow to fix due to it not affecting performance.
I turn off the router then turn it back on to remove the flashing wifi light however of late it usually returns within a week so the problem  is getting worse imo.
  • 7.55K
  • 593
  • 1.28K
Legend
Message 5 of 5
The only long term fix seems to be some black tape!
