Roger_Gooner
  • 8.76K
  • 560
  • 1.67K
Message 11 of 19
Re: Firestick wont connect to Hub4
You plug it into the Stick's micro USB port, the USB goes to the existing plug for power and the Ethernet cable goes to your hub.
Amazon makes its own Ethernet adapter as well.
https://www.amazon.co.uk/Amazon-Ethernet-Adaptor-Remote-models/dp/B01LXP5TXI/ref=sr_1_1?keywords=fir...
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG108S 8-port gigabit switch, V6
My Broadband Ping - Roger's VM broadband connection
Micheleboulton
  • 13
Message 12 of 19
Thanks for the explanation....if you can appreciate this really is annoying that i have to spend money on something that has a possibility of not working, especially when it worked without this before for nearly 2 years and worked on my daughters tv without it.
If changes have been made by Virgin to stop the stick from connecting it should be financed by Virgin!
Micheleboulton
  • 13
Message 13 of 19
My hub has no spare ethernet slots, i will have to sort in the morning and track what they all feed before i order one
Roger_Gooner
  • 8.76K
  • 560
  • 1.67K
Message 14 of 19
For a variety of reasons your device(s) may not get a strong enough WiFi signal (this happened to me with my V6), so you need a wired connection. If you lack a spare LAN port then get some more by using a gigabit switch - look at my sig for an example of such a switch.
David_Bn
  • 9.44K
  • 396
  • 722
Message 15 of 19
Good Morning @Micheleboulton, hope you're keeping well.
Do you possibly have any updates for us on the connection to the Firestick?
Have you been able to take time to consider the options provided by @Roger_Gooner?
Kindest regards,
David_Bn
Micheleboulton
  • 13
Message 16 of 19
Roger
Ive purchased an Amazon ethernet adaptor and have managed to grab 5 mins to fit and its WORKED but ive had to disconnect my CCTV. Would you recommend which switch is best for me, ive had a look and think if i got an 8 port one it will allow any further expansion that may occur.  What do you think of below?  I may be able to hard wire the bird box now too.
https://www.amazon.co.uk/gp/aw/d/B00A121WN6/ref=psdcmw_430573031_t2_B07HP6ZLSM
I really appreciate your help with this solution
Thank you!
Roger_Gooner
  • 8.76K
  • 560
  • 1.67K
Message 17 of 19
If you look at my sig I think it's the same as I've got.
Micheleboulton
  • 13
Message 18 of 19
Switch ordered and installed.  The firestick wouldnt work plugged into the switch so swapped it about and back into the hub.
Everything now fully working..
Thank you
Kain_W
  • 3.77K
  • 105
  • 268
Message 19 of 19
Thanks for the update Micheleboulton,
I'm glad that is sorted for you now.
Do let us know if you require further assistance.
All the best,
Kain
