  • 6
Message 1 of 16
Firestick and Ethernet
I'm struggling with my wifi connection to my Firestick so I've purchased a Cat8 ethernet cable and have it connected this way. I'm on a 200mb connection but when I run a speed test a barely get around 25mbs. When I plug the same cable into my laptop though I get over 220mbs.
Why is it so slow to my Firestick?
Any help to improve matters would be apprecaited!
  • 25.12K
  • 1.44K
  • 3.2K
Message 2 of 16
Re: Firestick and Ethernet
Firesticks aren’t meant to be super fast. It’s just one of the downsides of them.
  • 12.23K
  • 947
  • 1.57K
Message 3 of 16
With the ethernet cable connected to the Firestick login to the Hub Settings and navigate to the Connected Devices page - what does it report the 'connection speed’ as for the Firestick ?
Mike Robinson
  • 6
Message 4 of 16
Thanks for your help.....
amazon-11fccd328**:**:**:**:**:**192.168.0.20/24100Ethernet
  • 21
  • 8
  • 6
Message 5 of 16
The Firestick does not have an ethernet connection so what are you using as the ethernet adaptor?
  • 6
Message 6 of 16
I’m using the Amazon adaptor specifically for this purpose.
  • 6
Message 7 of 16
So this reports a speed of 100Mbps but when I run a test on an App on the Firestick it reports 25Mbps. Which is right?
  • 12.23K
  • 947
  • 1.57K
Message 8 of 16
TBH the speed that you are getting I would consider as excellent for an HDM connection.
Mike Robinson
  • 25.12K
  • 1.44K
  • 3.2K
Message 9 of 16
It's a theoretical throughput speed
  • 6
Message 10 of 16
So the conclusion is that the Firestick isnt able to handle high speeds?
Even when I plug the cable direct into the TV, the only get around 20Mbs there. Why would this be?
