  • 10
Message 11 of 21
Re: FireHD and Echo
Found the hub and entered the password.
  • 20.96K
  • 1.13K
  • 2.7K
Message 12 of 21
Re: FireHD and Echo
For Amazon Echo devices you have to put them back into setup mode then use the Alexa app to set it up again on the new WiFi.
Was this done?
  • 10
Message 13 of 21
Re: FireHD and Echo
Yes followed all the correct procedures for echo. Connects to WiFi but cannot connect to internet.
Kindle Fire HD finds WiFi, enter password and it searches and comes up with “authentication problems”
Have tried disabling security settings etc, still no luck. The older kindle found WiFi and accepted password no problem.
Message 14 of 21
Re: FireHD and Echo
Has anyone solved this problem or been able to help? This exact thing happened to me. My amazon fire won't connect, when it had been working fine up until yesterday.
  • 20.96K
  • 1.13K
  • 2.7K
Message 15 of 21
Re: FireHD and Echo
Try a 60 second pinhole reset on the hub
Message 16 of 21
Re: FireHD and Echo
Thanks for getting back to me Gary. I've tried that and its still not working. Is there anything else I can try?
Ive also reset my Fire to factory settings. That didn't work either
  • 20.96K
  • 1.13K
  • 2.7K
Message 17 of 21
Re: FireHD and Echo
Disable “smart” WiFi in the hubs admin pages
Message 18 of 21
Re: FireHD and Echo
Hi Gary,
I have no idea where to start doing that! Would you be able to give me some guidance? can this be done by pressing something on the main hub?
  • 4.72K
  • 868
  • 1.25K
Message 19 of 21
Re: FireHD and Echo
Hello
I am aware that some devices have problems connecting to the hub when smart wifi is turn on, so lets get it turned off.
Login into the hub at http://192.168.0.1 using the details from the base of the hub on a sticker.
When in goto "Advanced Settings", "Wireless", then "Wireless Signal", place a tick in circle where it says "Disable Channel Optimization" and then click on "Apply Changes".
That should solve your problem with connecting to the hub.
Regards Mike
Message 20 of 21
Re: FireHD and Echo
Hi Mike,
Thank you for your help. I have followed your steps to disable smart wifi and its still not working! I turned the booster off and back on and tried to reconnect and its still saying 'authentication error'.
