  • 11
Message 1 of 19
Fibre keeps dropping out
Ive been having problems for the last month with my connection dropping out. So far I’ve had my modem replaced and that’s given way faster speeds BUT I’m still having to restart 4/5 times a day when I’m the only device connected. This fixes things but obviously kicks me out of Zoom calls and makes working from cloud docs a nightmare.
I finally got a technician around last night who ‘changed a faulty connection in PLT (?) and changed WiFi settings’.
This morning I was kicked off a zoom call so clearly issue isn’t fixed.
Can anyone offer any solutions as this is driving me up the wall and I can’t work - or get hold of anyone on the phone. 2 calls kicked out of the queue today after an hour each 🤯
Jen
Tags (1)
  • 11
Message 2 of 19
Fibre dropping out
Jen
Tags (1)
  • 24.81K
  • 1.43K
  • 3.16K
Message 3 of 19
Re: Fibre keeps dropping out
Do wired connections also drop?
Anonymous
Not applicable
Message 4 of 19
If you’re doing any kind of zoom/Teams calls, then if you can use an Ethernet cable, rather than WiFi. Also, the home hub is not really optimal for working from home/video meetings, its a home device. So investing in a new router that offers QOS (Quality of Service, you can prioritise your Zoom/Teams calls over all the other data flowing on your network), would be a benefit.
  • 11
Message 5 of 19
I have a Lenovo netbook which doesn’t have a port to connect to modem via cable so I haven’t been able to test this.
Would this not have been tested by the tech who came yesterday though?
thanks
jen
  • 11
Message 6 of 19
Thanks for the response. The thing is it’s dropping off when I’m the only device connecting. I could completely understand needing a better modem if I had lots of traffic but I don’t, it’s just me connecting from within the same room as the modem.
Surely this should work on a home network? Thanks
Jen
  • 24.81K
  • 1.43K
  • 3.16K
Message 7 of 19
@JenG wrote:
thanks
jen
No. That’s for users to check.
If it’s just Wi-Fi dropping then it’s not a network issue and therefore nothing for Virgin to fix.
  • 17.45K
  • 1.84K
  • 3.04K
Message 8 of 19
JFYI - You can connect any laptop to the Hub by ethernet cable if you get the right "adapter". My MacbookAir has no ethernet port - but I have a USB3-RJ45 adapter which does the job nicely. Others are available for other lappy ports - USBc, Thunderbolt, Firewire, MicroUSB, etc., - form the usual online places for <£10. Get a good Cat6 patch cable at the same time 🙂
  • 3.65K
  • 284
  • 513
Superfast
Message 9 of 19
@JenG wrote:
Jen
We can at least check the HUB stats to ensure they are in spec.
Could you access your router using http://192.168.0.1/ or http://192.168.100.1 for modem mode . You shouldn't need log in, select the 'Check Router Status' option and paste your 'Downstream', 'Upstream', and 'Network Log' tabs? Please copy/paste this data as text, split between multiple posts (Sometimes you have to click 'Post' twice due to an error message).
Could you please create a BQM (Broadband Quality Monitor) here, and post the live link?
Anonymous
Not applicable
Message 10 of 19
Hi Jen, here’s some adapters that will work 🙂 https://www.amazon.co.uk/s?k=usb+ethernet+adapter&crid=2G9IPF7H5A5YE&sprefix=USB+eth%2Caps%2C173&ref...
pick one that matches the ports on your laptop 🙂
