  • 10
Message 1 of 14
Fibre connection regularly lost.
Hello all, new guy here.
Our Internet connection regularly goes down for prolonged periods without apparent cause or pattern. It's NOT the Wi-Fi, I know the difference and all my internal communications, CCTV, NAS etc can still be operated locally.
Our VM Hub 3 and TV package, was installed in September this year utilising cabling from a previous install/contract 10 years ago that we had till 4 years ago before switching to Vodafone.
We switched because of similar issues as we're having now, despite VM changing the cables to the house from the cabinet up the street, which were never resolved. We switched back to VM because Vodafone kept messing up the billing and the proffered VM package was much better and we assumed that the previous problems would no longer exist.
I occasionally work from home but my wife has been forced to, since the beginning of the year so this is more of a problem for here and my 9yr old.
I will post logs etc to here, shortly and suffice to say I have tried all of the actions advised both on this forum and on VM's website.
I have spent hours on hold to VM just be regularly cut off after 45m before getting to talking to a human and have once or twice even gotten as far as being passed on to another department then waiting a further hour before finally being cut off. I'm not going to get into the pro's and con's of outsourcing technical support but this morning, Sunday 15th Nov I got through to a UK customer support worker who arranged the first available engineer visit for 22nd Nov.
I recall our installation engineer from Sept stated that we had a low SNR and swapped out the connections on the ends of the cables and the old splitter.
Like all new customers, we were advised that the connection would need time to settle down and could drop out periodically but I think it should be settled in nicely by now, not getting worse.
Obviously an engineer has finally been arranged but on previous experience I don't have faith in this resolving the problem so any advice would be very much welcome.
BQM
  • 12.27K
  • 950
  • 1.57K
Message 2 of 14
Re: Fibre connection regularly lost.
Your >> BQM << looks good apart from what looks like a reboot at 11:30
Can you please
Mike Robinson
  • 10
Message 3 of 14
I only sorted the BQM last night and the first drop out was at just before 11:45 today. I assume the log entries from 1970 are due to a loss of connection and not my router travelling back in time?
Cable Modem StatusItemStatusCommentsAcquired Downstream Channel (Hz)
506250000
Locked
Ranged Upstream Channel (Hz)
46199928
Locked
Provisioning State
Online
1 506250000 1.5 40 256 qam 13
2 514250000 1.5 40 256 qam 14
3 522250000 1.2 40 256 qam 15
4 530250000 1 40 256 qam 16
5 538250000 0.5 38 256 qam 17
6 546250000 0.9 38 256 qam 18
7 554250000 1.5 38 256 qam 19
8 562250000 1.7 40 256 qam 20
9 570250000 1.5 40 256 qam 21
10 578250000 1.5 38 256 qam 22
11 586250000 1.4 38 256 qam 23
12 594250000 1.4 40 256 qam 24
13 602250000 1.5 38 256 qam 25
14 610250000 1.2 40 256 qam 26
15 618250000 1 40 256 qam 27
16 658250000 0 38 256 qam 28
17 666250000 0 38 256 qam 29
18 674250000 -0.4 38 256 qam 30
19 682250000 -0.5 38 256 qam 31
20 690250000 -0.9 38 256 qam 32
21 698250000 -0.9 38 256 qam 33
22 706250000 -1 38 256 qam 34
23 714250000 -1.2 38 256 qam 35
24 722250000 -1.5 38 256 qam 36
1 Locked 40.3 1 0
2 Locked 40.3 5 0
3 Locked 40.9 7 0
4 Locked 40.9 6 0
5 Locked 38.9 10 0
6 Locked 38.9 11 0
7 Locked 38.9 5 0
8 Locked 40.3 6 0
9 Locked 40.3 17 0
10 Locked 38.9 21 0
11 Locked 38.9 16 0
12 Locked 40.9 0 0
13 Locked 38.9 4 0
14 Locked 40.3 5 0
15 Locked 40.3 1 0
16 Locked 38.9 20 0
17 Locked 38.9 6 0
18 Locked 38.6 5 0
19 Locked 38.6 7 0
20 Locked 38.9 8 0
21 Locked 38.9 7 0
22 Locked 38.9 6 0
23 Locked 38.6 13 0
24 Locked 38.9 8 0
1 46199928 57 5120 64 qam 5
1 ATDMA 0 0 0 0
General Configuration
Network access Allowed
Maximum Number of CPEs 1
Baseline Privacy Enabled
DOCSIS Mode Docsis30
Config file cmreg-vmdg505-bbt060+voc-b.cm
SFID 1014000
Max Traffic Rate 230000061
Max Traffic Burst 42600
Min Traffic Rate 0
Primary Upstream Service Flow
SFID 1013999
Max Traffic Rate 22000061
Min Traffic Rate 0
Max Concatenated Burst 42600
Scheduling Type BestEffort
15/11/2020 12:03:13 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 11:48:7 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 11:43:2 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 21:37:46 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 01:02:51 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 01:02:26 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:45:43 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:44:40 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:44:9 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:43:15 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:41:17 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:40:16 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:38:21 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:37:18 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:36:43 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:36:34 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:35:23 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:34:20 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:33:50 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:32:52 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 12.27K
  • 950
  • 1.57K
Message 4 of 14
You only have one upstream Channel, we would expect to see four and the Power Level on that one Channels is too high.
Try a reboot to see if the Hub can renegotiate a better connection using this method ...
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then try your connection again.
It may or may not work, if it doesn't you will need an engineer to put things right.
You can either call in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
Mike Robinson
  • 25.14K
  • 1.44K
  • 3.2K
Message 5 of 14
Can you post the upstream stats again?
  • 10
Message 6 of 14
Cable Modem Status
Item Status Comments
Acquired Downstream Channel (Hz) 506250000 Locked
Ranged Upstream Channel (Hz) 46200000 Locked
Provisioning State Online
1 506250000 1.7 40 256 qam 13
3 522250000 1.4 40 256 qam 15
5 538250000 0.7 40 256 qam 17
6 546250000 1.2 38 256 qam 18
7 554250000 2 38 256 qam 19
8 562250000 2 40 256 qam 20
9 570250000 1.9 40 256 qam 21
10 578250000 1.9 38 256 qam 22
11 586250000 1.5 38 256 qam 23
12 594250000 1.7 40 256 qam 24
13 602250000 1.9 38 256 qam 25
14 610250000 1.5 40 256 qam 26
15 618250000 1.4 40 256 qam 27
16 658250000 0.2 38 256 qam 28
18 674250000 -0.2 38 256 qam 30
19 682250000 -0.4 38 256 qam 31
20 690250000 -0.7 38 256 qam 32
21 698250000 -0.7 38 256 qam 33
22 706250000 -0.7 38 256 qam 34
23 714250000 -1 38 256 qam 35
24 722250000 -1.2 38 256 qam 36
1 Locked 40.3 0 0
2 Locked 40.3 6 0
3 Locked 40.3 0 0
4 Locked 40.3 6 0
5 Locked 40.3 0 0
6 Locked 38.9 0 0
7 Locked 38.9 5 0
8 Locked 40.3 16 0
9 Locked 40.3 18 0
10 Locked 38.9 18 0
11 Locked 38.9 13 0
12 Locked 40.3 12 0
13 Locked 38.9 5 0
14 Locked 40.3 0 0
15 Locked 40.3 0 0
16 Locked 38.9 14 0
17 Locked 38.9 5 0
18 Locked 38.6 1 0
19 Locked 38.6 2 0
20 Locked 38.9 1 0
21 Locked 38.9 6 0
22 Locked 38.9 5 0
23 Locked 38.9 11 0
24 Locked 38.6 6 0
1 46200000 51 5120 64 qam 5
2 32599961 51 5120 64 qam 7
3 25800288 51 5120 64 qam 8
4 39400108 51 5120 64 qam 6
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
SFID 1014192
Min Traffic Rate 0
SFID 1014191
Min Traffic Rate 0
15/11/2020 14:03:14 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 10
Message 7 of 14
Ok, so I did as Mike asked and then copied the logs as above but two minutes after it reconnected, it went off again of it's own accord and is still off so I'm "borrowing" next doors talktalk...........
  • 10
Message 8 of 14
I have to go out of the house now so I wont be able to do anything to the router for a while. I live near Birmingham so feel free to pop in and fix it whilst I'm out.
  • 3.67K
  • 288
  • 516
Superfast
Message 9 of 14
It looks like your upstream power levels need adjusting:
  • 25.14K
  • 1.44K
  • 3.2K
Message 10 of 14
Your upstream levels are maxed out. Unless there’s an area issue you’ll need an engineer visit.
