Fibre cable damage in area
Sunflower4
So I’ve just moved flats and set up my new VM hub 3 in Newcastle city centre which worked perfectly on day it arrived. Then the following day it stopped working and it seems that there has been an internet issue in my area where there has been fibre cables damaged. It has been 4 days that I’ve had 0 internet and I’m really struggling to work etc. without it. They are sending me text updates telling me a time it will be fixed by but then this just extends every day so it feels hopeless!
Does anyone know how long this type of thing usually takes and whether they actually do have engineers working on the problem or if it’s just a generic text? And whether you get some sort of compensation for having a terrible service that you’re paying for?
Thanks!
1 ACCEPTED SOLUTION
Accepted Solutions
See this...
________
Try in 2 places
1) Try the “check service,”Area status webpage (https://www.virginmedia.com/help/service-status)
2) Then also Try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues down to street cab/ postcode level.
The "compensation "timer" can also be started on this number if appropriate.
1 REPLY 1
See this...
________
Try in 2 places
