Martyn_R
Message 1 of 7
Faulty Hub3 ?
I think my Hub 3 is faulty.  No issues with ethernet connections.  No broadband issues reported in my postcode.  I have Intermittant WiFi connection.  I have tried switching hub off and resetting hub.  I have used the online tools to try to fix problems. I have tried to put hub in modem mode but only get single RED light (overheat ?)  Can anyone help in deciphering the log below?
WiFi appears to be better since yesterdays reset but I have done this before and issues recur.
Many thanks Martyn
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
659000000
-3.4
37
256 qam
32
2
475000000
-0.2
37
256 qam
9
3
483000000
-0.4
37
256 qam
10
4
491000000
-0.4
37
256 qam
11
5
499000000
-0.5
37
256 qam
12
6
507000000
-0.5
37
256 qam
13
7
515000000
-0.5
37
256 qam
14
8
523000000
-0.9
37
256 qam
15
9
531000000
-1.2
37
256 qam
16
10
539000000
-1.5
37
256 qam
17
11
547000000
-1.5
37
256 qam
18
12
555000000
-1.7
37
256 qam
19
13
563000000
-1.9
37
256 qam
20
14
571000000
-2.2
37
256 qam
21
15
579000000
-2.4
37
256 qam
22
16
587000000
-2.5
37
256 qam
23
17
595000000
-2.7
37
256 qam
24
18
603000000
-2.7
37
256 qam
25
19
611000000
-2.7
37
256 qam
26
20
619000000
-3
37
256 qam
27
21
627000000
-3
37
256 qam
28
22
635000000
-3
37
256 qam
29
23
643000000
-3.2
37
256 qam
30
24
651000000
-3.2
37
256 qam
31
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
37.3
159
0
2
Locked
37.6
25
0
3
Locked
37.6
34
0
4
Locked
37.6
31
0
5
Locked
37.6
26
0
6
Locked
37.6
29
0
7
Locked
37.6
31
0
8
Locked
37.6
29
0
9
Locked
37.6
39
0
10
Locked
37.3
39
0
11
Locked
37.3
57
0
12
Locked
37.3
57
0
13
Locked
37.6
58
0
14
Locked
37.3
69
0
15
Locked
37.3
55
0
16
Locked
37.6
96
0
17
Locked
37.6
93
0
18
Locked
37.3
115
0
19
Locked
37.3
107
0
20
Locked
37.6
128
0
21
Locked
37.3
117
0
22
Locked
37.3
143
0
23
Locked
37.6
135
0
24
Locked
37.6
165
0
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
60300294
41.8
5120
64 qam
1
2
39400134
40.3
5120
64 qam
4
3
53700078
41.5
5120
64 qam
2
4
46200020
41
5120
64 qam
3
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
1
0
2
ATDMA
0
0
1
0
3
ATDMA
0
0
3
0
4
ATDMA
0
0
2
0
Time
Priority
Description
19/07/2021 11:49:6
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.0;
18/07/2021 14:28:3
critical
No Ranging Response received - T3 time-out;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.0;
18/07/2021 11:17:39
notice
LAN login Success;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:02:3
critical
18/07/2021 10:46:51
notice
01/01/1970 00:02:3
critical
18/07/2021 10:29:53
notice
01/01/1970 00:02:1
critical
18/07/2021 09:55:23
notice
NOTICE ATOM is restarted as part of Self Healing Mechanism;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.0;
18/07/2021 09:50:26
notice
18/07/2021 05:05:7
notice
18/07/2021 04:56:33
notice
17/07/2021 16:12:7
critical
17/07/2021 14:57:5
notice
17/07/2021 07:39:29
critical
No Ranging Response received - T3 time-out;CM-MAC=XXX;CMTS-MAC=X;CM-QOS=1.1;CM-VER=3.0;
17/07/2021 01:30:45
notice
16/07/2021 04:27:57
critical
16/07/2021 04:03:28
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.0;
13/07/2021 15:58:9
critical
13/07/2021 11:32:53
Error
lotharmat
  • 2.54K
  • 190
  • 462
Trouble shooter
Message 2 of 7
Re: Faulty Hub3 ?
Stats don't look bad - a few T3 timeouts (of which a handful are to be expected and the drops when that happens will affect ethernet connections too)
In Modem mode - the light is supposed to be magenta (mine is red as well though)
DO all WiFi connections drop at the same time! (You may have got my old hub if they do) if so that would definitely indicate a fault!
Martyn_R
Message 3 of 7
Re: Faulty Hub3 ?
Yes, all WiFi connections do drop out at the same time.
Thanks for the info about the "Magenta" light.  I might try modem mode if the Wifi fails again.
WiFi has been OK for the last 24 hours, longest uptime for weeks.
Thanks for the comments on the log.
Andrew-G
  • 6.92K
  • 1.21K
  • 3.02K
Message 4 of 7
Re: Faulty Hub3 ?
I'm suspicious of that network log - four T3 timeouts per day is far too high, and the "Atom is restarting" message is often associated with a failing hub?
Martyn_R
Message 5 of 7
Re: Faulty Hub3 ?
If I run the VM diagnostic test "No network issue is found" but when I click on "View connected devices" I get ...
Any ideas?
Martyn_R
Message 6 of 7
Re: Faulty Hub3 ?
Image above just says...
Technical error
Something's gone wrong. To get you to the right help, go back to service status.
Which takes me round an endless loop !
Laurie_C
  • 816
  • 27
  • 80
Message 7 of 7
Re: Faulty Hub3 ?
Hi Martyn_R,
Thanks for getting in touch, and a very warm welcome to the Community Forum. I'm sorry that you're having some issues with your Hub.
I've been able to locate your account using your Forum Details, and I can see that there our diagnostic checks are returning some errors. I'd therefore like to book a technician appointment for you. I'll just need to confirm a few details via Private Message. Please look out for a purple envelope in the top right corner of this page.
Kind regards,
Laurie
Laurie_C
