Just joined
Fault with WiFi
Our WiFi is not working properly (since Friday) . I was on hold for an hour yesterday before getting cut off. I finally got through today to a lady (second line response or something) who was fairly rude and unhelpful on the phone and constantly talked over me. And when I asked for her name she put the phone down on me!! All she could tell me was that the network was unstable and she would ‘send a signal’ to fix it POSs in 24-48 hours. I’ve actually not experienced such poor customer service in a long time. Pls respond at your earliest convenience.
  • 11.57K
  • 898
  • 1.48K
Re: Fault with WiFi
Try a reboot using this method ...
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then try your connection again.
Mike Robinson
Retired Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 3.77K
  • 154
  • 219
Re: Fault with WiFi
Thanks for the post Kathryna68.
Can we please confirm how things are doing today?
Did you do a pin hole reset of the Hub?
Let us know, Emily.
