Fast speed, slow loading, broken websites
X-Morgan
Hi all, looking for help and advice.
Two weeks ago I noticed that my connection wasn't as stable. You kinda get used to how quickly pages load and notice anything out of the ordinary.
The biggest culprit was any speedtest results showing 200-220Mb, but pages like BBC News, Twitter, YouTube showing blank white pages and "establishing a secure connection" in Chrome. Once it was done it half-loaded a site with broken links as images.
It affected anything connected to the network (ethernet or Wi-Fi).
I assumed it would just resolve itself, but it didn't.
I would also get a lot of DNS style errors and "page failed to load" within Chrome or failed logins for anything using https. But if you left it on the error page, after about 60 seconds, it would load perfectly.
I've been backwards and forwards with tech support, however it's been no use as they just tried to sell me Wi-Fi Booster pods for some reason, or blame the fact that I'm running in modem mode (even though I told them that the issues persist even in router mode).
Yesterday I had an engineer out and he replaced my Superhub 2ac with a Superhub 3 and he said he went out to the signal box and tightened a few connections while he was there.
Power levels and other readings he said were now fine with the Hub 3 installed, but as the day went on, the issues were still there.
2 hours on Tech support yesterday and today have got me no closer other than being told "your connection is being monitored and will improve within 24 hours" but I've been told that about 6 times now over the last 2 weeks.
I checked these forums and noticed people having very similar issues (PSN, DNS, slow loading).
Any and all help is appreciated.
(Also, for info, I changed my DNS and the issue was still there)
If you need any details, please let me know.
50 REPLIES 50
Roger_Gooner
Do a pinhole reset for a good 30 seconds.
Can you post some stats.
Go to 192.168.0.1, do not log in, click on the link "Check Router Status".
Copy and paste the Downstream, Upstream and Network Logs as text (not images). Mask any public IP address.
Hub 5, TP-Link TL-SG108S 8-port gigabit switch, 360
My Broadband Ping - Roger's VM hub 5 broadband connection
Done the pinhole test twice now today when on call with Tech support and still having issues.
Ironically, just tried to reply and got a ERR_NAME_NOT_RESOLVED on Chrome. This was even after I flushed the DNS cache this morning.
11390000006.538256 qam1
21470000006.438256 qam2
31550000006.538256 qam3
41630000006.338256 qam4
51710000006.338256 qam5
61790000006.138256 qam6
7187000000638256 qam7
8195000000638256 qam8
92030000005.838256 qam9
102110000005.538256 qam10
112190000005.538256 qam11
12227000000538256 qam12
132350000004.838256 qam13
142430000004.538256 qam14
152510000004.138256 qam15
162590000003.738256 qam16
172670000003.538256 qam17
182750000004.538256 qam18
192830000004.538256 qam19
202910000004.538256 qam20
212990000004.838256 qam21
223070000004.838256 qam22
233150000004.538256 qam23
243230000004.838256 qam24
1Locked38.6110
2Locked38.6190
3Locked38.6290
4Locked38.9230
5Locked38.9220
6Locked38.9310
7Locked38.6210
8Locked38.670
9Locked38.970
10Locked38.950
11Locked38.670
12Locked38.9130
13Locked38.670
14Locked38.6130
15Locked38.9150
16Locked38.9190
17Locked38.670
18Locked38.6110
19Locked38.960
20Locked38.6120
21Locked38.6110
22Locked38.660
23Locked38.6190
24Locked38.6160
14960000042.5512064 qam1
24310000042.5512064 qam2
32359997142.3512032 qam5
43010000042.3512064 qam4
53660000042.3512064 qam3
1ATDMA0020
3ATDMA0000
4ATDMA0000
5ATDMA0000
08/10/2022 11:32:32noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/10/2022 19:03:9noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:38criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/10/2022 17:55:23noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/10/2022 09:58:39ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:56Warning!ToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:43criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/10/2022 08:55:59ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/10/2022 08:52:4noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/10/2022 08:51:24Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:03:30criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/10/2022 08:25:12noticeSW download Successful - Via Config file
07/10/2022 08:22:58noticeSW Download INIT - Via Config file
01/01/1970 00:04:51noticeUnit has been restored to factory defaults from a software issued command;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:04:26noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/07/2022 13:20:48criticalTLV-11 - Failed to set duplicate elements;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/07/2022 13:18:2noticeUnit has been restored to factory defaults from a software issued command;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/07/2022 13:03:17criticalTLV-11 - Failed to set duplicate elements;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/07/2022 13:00:47noticeSW download Successful - Via Config file
Apart from possible noise on one of the upstream channels I'm not seeing much wrong. Can you try a different browser?
It's not the browser that's the issue, it's just a symptom of an unknown larger issue which affects anything that's connected, be it WiFi or ethernet.
Just tried Twitter there on my phone and when it's on WiFi, it'll take 40-60 seconds to refresh the feed, and it refreshes instantly when it's on 4G/5G.
**Update - Error messages would flash up over the last two weeks that I couldn't see since they changed so fast, but I saw a DNS_PROBE_FINISHED_NXDOMAIN just 2 minutes ago**
change DNS to 194.168.4.123, 194.168.8.123 or 1.1.1.1, 8.8.8.8, 9.9.9.9
I've went through Virgin, Google and Cloudflare's DNS the past 2 weeks and still the same. Which surprised me.
Still getting these errors and nothing requiring a login will load properly.
Getting lots of 'DNS PROBE FINISHED NXDOMAIN' errors, only for the page to load up 30 seconds later and pages half loading with broken thumbnails where images should be.
Superhub is still on router mode as tech support over the phone says it allows them to run tests, but I'm not holding my breath.
The browser error messages are symptoms currently affecting all chronium based browsers, Chrome being the main culprit. It's especially bad on the VM website.
I had a multitide of those errors on my previous PC which was sometimes fixed by clearing browsing data or using an incognito window.
I had also uninstalled and reinstalled the browsers however the issues kept reappearing.
I've had no issues whatsover on the AIO PC that bought a couple of months leading to me to believe that the browser data was corrupt.
Dave
The do's and don'ts.
