Factory reset Hub 3 then update to latest firmware WILL remove malware?
3 weeks ago
Could someone give guidance on how to fully factory reset my virgin router and then update to latest firmware. I don't think my router has ever had an update. And I suspect malware is a factor. Please advise.
Re: Factory reset Hub 3 then update to latest firmware WILL remove malware?
3 weeks ago
Hey Client62
My goal is to reset and then update to the latest software, manually if possible. Also does the link you provided help with malware on the router itself? Thanks.
