Hello,
My hub 3.0 worked fine until recently. Now even though the lights on the hub don't indicate an issue: power light is white as per 'normal' and the other lights are unlit), the WIFI network isn't visible to any of my devices whilst the ethernet connection is fine.
I've tried both restarting the hub and hard resetting it via the hole on the hub. After a reset, the WIFI network IS available and I can then set up an SSID for each frequency and change the passwords etc. However this is not a permanent fix. After a day or less, the same thing happens. The WIFI network disappears even though the ethernet ports work fine and I need reset the hub again then change all the settings only for the to disappear a short time afterwards.
I have tried calling support but he wait times are exceedingly long due to C19. Is there any way a VM team member can assist me with getting a replacement hub please? This was a self install so I don't need an engineer visit just a new, or new to me, hub.
Thanks.
