on 16-08-2023 16:46
Since about mid last month my connection has become worse and worse the latency spikes have gone up and up and have become more frequent, This needs sorting its not suitable for gaming or for work calls when I have these latency spikes which are often a lot worse in the evening.
Here is the info from Network Tools on the Hub 5
Acquired Downstream Channel(Hz) | 139000000 | Locked |
Ranged Upstream Channel(Hz) | 49600000 | Ranged |
Provisioning State | Online | Operational |
Downstream:
1 | 139000000 | 10 | 39 | QAM 256 | 1 |
2 | 147000000 | 9.7 | 39 | QAM 256 | 2 |
3 | 155000000 | 9.6 | 39 | QAM 256 | 3 |
4 | 163000000 | 9.3 | 39 | QAM 256 | 4 |
5 | 171000000 | 8.9 | 39 | QAM 256 | 5 |
6 | 179000000 | 8.9 | 39 | QAM 256 | 6 |
7 | 187000000 | 8.9 | 39 | QAM 256 | 7 |
8 | 195000000 | 8.7 | 39 | QAM 256 | 8 |
9 | 203000000 | 8.4 | 39 | QAM 256 | 9 |
10 | 211000000 | 8.4 | 39 | QAM 256 | 10 |
11 | 219000000 | 8.3 | 39 | QAM 256 | 11 |
12 | 227000000 | 7.9 | 39 | QAM 256 | 12 |
13 | 235000000 | 7.3 | 39 | QAM 256 | 13 |
14 | 243000000 | 6.8 | 39 | QAM 256 | 14 |
15 | 251000000 | 6.6 | 39 | QAM 256 | 15 |
16 | 259000000 | 6.4 | 39 | QAM 256 | 16 |
17 | 267000000 | 6.2 | 39 | QAM 256 | 17 |
18 | 275000000 | 6.3 | 39 | QAM 256 | 18 |
19 | 283000000 | 6.7 | 39 | QAM 256 | 19 |
20 | 291000000 | 7.5 | 40 | QAM 256 | 20 |
21 | 299000000 | 7.5 | 40 | QAM 256 | 21 |
22 | 307000000 | 7.5 | 40 | QAM 256 | 22 |
23 | 315000000 | 7.7 | 40 | QAM 256 | 23 |
24 | 323000000 | 8 | 40 | QAM 256 | 24 |
25 | 331000000 | 8.1 | 40 | QAM 256 | 25 |
26 | 339000000 | 8.2 | 40 | QAM 256 | 26 |
27 | 347000000 | 8 | 40 | QAM 256 | 27 |
28 | 355000000 | 8.3 | 40 | QAM 256 | 28 |
29 | 363000000 | 8.4 | 40 | QAM 256 | 29 |
30 | 371000000 | 8.4 | 40 | QAM 256 | 30 |
31 | 379000000 | 8.7 | 40 | QAM 256 | 31 |
1 | Locked | 39 | 874 | 0 |
2 | Locked | 39 | 845 | 15 |
3 | Locked | 39 | 792 | 25 |
4 | Locked | 39 | 804 | 14 |
5 | Locked | 39 | 820 | 0 |
6 | Locked | 39 | 825 | 10 |
7 | Locked | 39 | 807 | 0 |
8 | Locked | 39 | 804 | 4 |
9 | Locked | 39 | 844 | 13 |
10 | Locked | 39 | 827 | 14 |
11 | Locked | 39 | 759 | 67 |
12 | Locked | 39 | 797 | 0 |
13 | Locked | 39 | 807 | 13 |
14 | Locked | 39 | 786 | 0 |
15 | Locked | 39 | 802 | 0 |
16 | Locked | 39 | 778 | 3 |
17 | Locked | 39 | 783 | 11 |
18 | Locked | 39 | 804 | 12 |
19 | Locked | 39 | 962 | 15 |
20 | Locked | 40 | 751 | 13 |
21 | Locked | 40 | 705 | 0 |
22 | Locked | 40 | 701 | 12 |
23 | Locked | 40 | 604 | 11 |
24 | Locked | 40 | 604 | 0 |
25 | Locked | 40 | 575 | 0 |
26 | Locked | 40 | 636 | 0 |
27 | Locked | 40 | 588 | 0 |
28 | Locked | 40 | 605 | 11 |
29 | Locked | 40 | 566 | 64 |
30 | Locked | 40 | 522 | 0 |
31 | Locked | 40 | 487 | 0 |
Upstream:
0 | 49600000 | 48.5 | 5120 | QAM 64 | 1 |
1 | 43100000 | 48.5 | 5120 | QAM 64 | 2 |
2 | 36600000 | 48.5 | 5120 | QAM 64 | 3 |
3 | 30100000 | 48 | 5120 | QAM 64 | 4 |
4 | 23600000 | 47.5 | 5120 | QAM 64 | 5 |
0 | ATDMA | 0 | 0 | 0 | 0 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 2 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 2 | 0 |
Configuration:
General Configuration
Allowed |
1 |
Enabled |
3.1 |
UBsgvca69834ncxv9873254k; |
602 |
1200000450 bps |
42600bytes |
0 bps |
Primary Upstream Service Flow
601 |
110000274 bps |
42600bytes |
0 bps |
42600bytes |
Best Effort |
Below are the BQM charts for 01/08/2023-15/08/2023
on 19-08-2023 11:39
Rebooted and monitored for 24h, while the spikes are not as large as previous graphs I am still getting big spikes and now seems like I also have some packet loss.
on 21-08-2023 08:28
Hi @MauriceMoss, thank you for the update.
In order to look into this for you further, we'll send you a private message on here. Look out for the envelope in the top right-hand corner.
Regards,
Daniel
