on 16-08-2023 16:46
Since about mid last month my connection has become worse and worse the latency spikes have gone up and up and have become more frequent, This needs sorting its not suitable for gaming or for work calls when I have these latency spikes which are often a lot worse in the evening.
Here is the info from Network Tools on the Hub 5
Acquired Downstream Channel(Hz) | 139000000 | Locked |
Ranged Upstream Channel(Hz) | 49600000 | Ranged |
Provisioning State | Online | Operational |
Downstream:
1 | 139000000 | 10 | 39 | QAM 256 | 1 |
2 | 147000000 | 9.7 | 39 | QAM 256 | 2 |
3 | 155000000 | 9.6 | 39 | QAM 256 | 3 |
4 | 163000000 | 9.3 | 39 | QAM 256 | 4 |
5 | 171000000 | 8.9 | 39 | QAM 256 | 5 |
6 | 179000000 | 8.9 | 39 | QAM 256 | 6 |
7 | 187000000 | 8.9 | 39 | QAM 256 | 7 |
8 | 195000000 | 8.7 | 39 | QAM 256 | 8 |
9 | 203000000 | 8.4 | 39 | QAM 256 | 9 |
10 | 211000000 | 8.4 | 39 | QAM 256 | 10 |
11 | 219000000 | 8.3 | 39 | QAM 256 | 11 |
12 | 227000000 | 7.9 | 39 | QAM 256 | 12 |
13 | 235000000 | 7.3 | 39 | QAM 256 | 13 |
14 | 243000000 | 6.8 | 39 | QAM 256 | 14 |
15 | 251000000 | 6.6 | 39 | QAM 256 | 15 |
16 | 259000000 | 6.4 | 39 | QAM 256 | 16 |
17 | 267000000 | 6.2 | 39 | QAM 256 | 17 |
18 | 275000000 | 6.3 | 39 | QAM 256 | 18 |
19 | 283000000 | 6.7 | 39 | QAM 256 | 19 |
20 | 291000000 | 7.5 | 40 | QAM 256 | 20 |
21 | 299000000 | 7.5 | 40 | QAM 256 | 21 |
22 | 307000000 | 7.5 | 40 | QAM 256 | 22 |
23 | 315000000 | 7.7 | 40 | QAM 256 | 23 |
24 | 323000000 | 8 | 40 | QAM 256 | 24 |
25 | 331000000 | 8.1 | 40 | QAM 256 | 25 |
26 | 339000000 | 8.2 | 40 | QAM 256 | 26 |
27 | 347000000 | 8 | 40 | QAM 256 | 27 |
28 | 355000000 | 8.3 | 40 | QAM 256 | 28 |
29 | 363000000 | 8.4 | 40 | QAM 256 | 29 |
30 | 371000000 | 8.4 | 40 | QAM 256 | 30 |
31 | 379000000 | 8.7 | 40 | QAM 256 | 31 |
1 | Locked | 39 | 874 | 0 |
2 | Locked | 39 | 845 | 15 |
3 | Locked | 39 | 792 | 25 |
4 | Locked | 39 | 804 | 14 |
5 | Locked | 39 | 820 | 0 |
6 | Locked | 39 | 825 | 10 |
7 | Locked | 39 | 807 | 0 |
8 | Locked | 39 | 804 | 4 |
9 | Locked | 39 | 844 | 13 |
10 | Locked | 39 | 827 | 14 |
11 | Locked | 39 | 759 | 67 |
12 | Locked | 39 | 797 | 0 |
13 | Locked | 39 | 807 | 13 |
14 | Locked | 39 | 786 | 0 |
15 | Locked | 39 | 802 | 0 |
16 | Locked | 39 | 778 | 3 |
17 | Locked | 39 | 783 | 11 |
18 | Locked | 39 | 804 | 12 |
19 | Locked | 39 | 962 | 15 |
20 | Locked | 40 | 751 | 13 |
21 | Locked | 40 | 705 | 0 |
22 | Locked | 40 | 701 | 12 |
23 | Locked | 40 | 604 | 11 |
24 | Locked | 40 | 604 | 0 |
25 | Locked | 40 | 575 | 0 |
26 | Locked | 40 | 636 | 0 |
27 | Locked | 40 | 588 | 0 |
28 | Locked | 40 | 605 | 11 |
29 | Locked | 40 | 566 | 64 |
30 | Locked | 40 | 522 | 0 |
31 | Locked | 40 | 487 | 0 |
Upstream:
0 | 49600000 | 48.5 | 5120 | QAM 64 | 1 |
1 | 43100000 | 48.5 | 5120 | QAM 64 | 2 |
2 | 36600000 | 48.5 | 5120 | QAM 64 | 3 |
3 | 30100000 | 48 | 5120 | QAM 64 | 4 |
4 | 23600000 | 47.5 | 5120 | QAM 64 | 5 |
0 | ATDMA | 0 | 0 | 0 | 0 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 2 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 2 | 0 |
Configuration:
General Configuration
Allowed |
1 |
Enabled |
3.1 |
UBsgvca69834ncxv9873254k; |
602 |
1200000450 bps |
42600bytes |
0 bps |
Primary Upstream Service Flow
601 |
110000274 bps |
42600bytes |
0 bps |
42600bytes |
Best Effort |
Below are the BQM charts for 01/08/2023-15/08/2023
on 16-08-2023 16:47
15-08-2023 16:48:06 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
15-08-2023 16:46:48 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
15-08-2023 16:46:48 | warning | Dynamic Range Window violation |
14-08-2023 05:10:01 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-08-2023 05:09:17 | error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
12-08-2023 13:17:02 | warning | Dynamic Range Window violation |
12-08-2023 13:17:02 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
12-08-2023 13:17:02 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
10-08-2023 17:09:35 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
10-08-2023 17:09:11 | error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-08-2023 13:21:44 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-08-2023 13:21:33 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-08-2023 13:21:33 | warning | Dynamic Range Window violation |
08-08-2023 07:11:17 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
08-08-2023 07:11:06 | warning | Dynamic Range Window violation |
08-08-2023 07:11:06 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
08-08-2023 06:27:02 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
08-08-2023 06:26:31 | warning | Dynamic Range Window violation |
08-08-2023 06:26:31 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
08-08-2023 03:56:56 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
08-08-2023 03:55:04 | warning | Dynamic Range Window violation |
08-08-2023 03:55:04 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
07-08-2023 05:47:03 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
07-08-2023 05:46:51 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
07-08-2023 05:46:51 | warning | Dynamic Range Window violation |
07-08-2023 05:09:11 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
07-08-2023 05:09:04 | error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
07-08-2023 04:27:05 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
07-08-2023 04:26:58 | warning | Dynamic Range Window violation |
07-08-2023 04:26:58 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
06-08-2023 15:06:22 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
06-08-2023 15:06:15 | warning | Dynamic Range Window violation |
on 16-08-2023 17:25
Might be nothing you can do but see if it happens in modem mode when you are idle
on 16-08-2023 17:29
The hub 5 is already in modem mode as it is connect to my unif gear
16-08-2023 18:01 - edited 16-08-2023 18:05
Ok see what happens if you rate limit download to 100Mb upload 20Mb use SFQ for QoS if the BQM still shows bad really nothing you can do.
on 16-08-2023 18:06
Forgot to mention in first post this is a Gig1 package.
on 16-08-2023 18:28
Start low then go higher if lower rate limiting still shows Extreme Latency VM will have to fix it
on 17-08-2023 20:59
Hi there @MauriceMoss
Thank you so much for your post and welcome back to the community forums, it's great to have you here.
I am so sorry to hear that you have faced this issue with your service and thank you to our community for their help so far.
I can see that the Hub has been up for around a month, would you be able to try a pin hole reset? To do this push a pen etc into the reset hole and hold in for 60 seconds.
on 17-08-2023 22:09
Ok rebooted the hub 5, will monitor till tomorrow but doubt it will resolve it.
on 17-08-2023 22:35
Looks like oversubscription.
