Message 1 of 9
External Hub
I need my external hub (brown box) moved due to construction work.
I have spoken to VM but I would like some clarity on the point they were making.
If they move the box, then the connection to the internal hub will be via WiFi and not cable. This could impact my Internet connection.
Is this correct? When my external box is moved it will no longer connect to the internal hub via cable but via a signal?
I thought they would just reconnect the cable!
Thanks for your help.
  • 24.89K
  • 1.44K
  • 3.17K
Message 2 of 9
Re: External Hub
The hub always needs to be connected by Coax to the wallbox.
  • 5.95K
  • 1.12K
  • 1.57K
Message 3 of 9
Re: External Hub
Hello
When they move the external brown box they will also reconnect the hub back upto to external box.
Regards Mike
Message 4 of 9
Re: External Hub
Thanks guys,
So we are taking the brown box off as the wall its connected to will no longer be there.
Can VM then fit a temporary external box whilst we have the front extension built and then connect the external box to the new front extension.
  • 1.7K
  • 93
  • 234
Superfast
Message 5 of 9
Re: External Hub
all this work will cost you £99 per engineer visit - have you factored that in?
you should not be removing the box yourself though.
all works, be it removing, and reconnecting should be done by virgin themselves.
My Broadband Ping - spgray
  • 24.89K
  • 1.44K
  • 3.17K
Message 6 of 9
Re: External Hub
I don't think they'll keep coming back and forth - usually things like this involve a standard call-out charge of £99 per visit
  • 5.95K
  • 1.12K
  • 1.57K
Message 7 of 9
Re: External Hub
Hello
Yes they will but you will need to be aware that would end up with 2 non callout charges of £99, it would be best for you to find a permanent place to put the box.
Regards Mike
Message 8 of 9
Re: External Hub
OK so the two options are 1) find a permanent place to refit the brown box on first visit and pay £99
or 2) have temporary external hub and then refit on front extension once built but pay two charges of £99.
  • 5.95K
  • 1.12K
  • 1.57K
Message 9 of 9
Re: External Hub
Hello
Yep those are the options.
Regards Mike
