  • 5
Message 1 of 12
Extension to Hub 3.0
I'm trying to get broadband in my shed at the bottom of the garden - I have a CAT6 cable running to the shed from the router - can I just plug it in to the router (with an ethernet socket), and plug the other end into a new router and it will work? Is that how it's done?
  • 2.22K
  • 144
  • 430
Problem sorter
Message 2 of 12
Re: Extension to Hub 3.0
You don't need another router, just an Access Point (AP), or a switch and AP, depending on if you want additional ethernet points in the shed.
  • 17.46K
  • 1.84K
  • 3.04K
Message 3 of 12
Yes - but you dont need a 2nd router - that's overkill. Just put a wireless access point on it
  • 5
Message 4 of 12
Thanks so much for your speedy reply! So is an Access Point just a socket, into which I can plug the ethernet cable that goes from my Mac?
Alternatively, if I wanted actual WiFi in the shed, could I plug a small wifi box into the AP or ethernet socket, so that I could get online via WiFi in the shed?
  • 5
Message 5 of 12
Sorry for being thick, but what is a Wireless Access Point?
  • 19.65K
  • 1.72K
  • 4.29K
Message 6 of 12
basically a switch with wireless capability
or An access point is a device that creates a wireless local area network, or WLAN, usually in an office or large building. An access point connects to a wired router, switch, or hub via an Ethernet cable, and projects a Wi-Fi signal to a designated area.
  • 5
Message 7 of 12
Oh - just googled it - I see what you mean. Any that you'd particularly recommend?
  • 17.46K
  • 1.84K
  • 3.04K
Message 8 of 12
There are some good ones that also have 4 ethernet ports that act as an "inbuilt switch". That has pro's and cons of course - its only one device to plug in but if one part fails then it all needs to be replaced rather than just a switch or separate (cheaper) WAP
Here is an example of a good one
https://www.amazon.co.uk/NETGEAR-AC2000-Wireless-Access-WAC124-100UKS/dp/B01N47QKDQ/
  • 5
Message 9 of 12
  • 24.82K
  • 1.43K
  • 3.16K
Message 10 of 12
It's only wireless N so will only extend the slower 2.4Ghz band.
TBH you can't cheap out on networking equipment.
