service1920
Message 1 of 5
Extending Wifi signal to garage
I am currently converting the Garage into an office and need to deliver the Wifi network into it.
There is currently NO wifi signal in the garage but I have power from the house. Therefore rather than a "boost" to a weak signal I need to extend the wifi there.
I have the PowerLine PL1000 in the rooms in the house for the Tivo and I see there is a possibility to buy a wireless version but I can only find it for approx £120 and with a european plug so if the network is being delivered over the electic circuit a EU to UK converter is bound not to help...
Thoughts please on the best options to establish the Wifi in my Garage.
  • 10.19K
  • 758
  • 2.15K
Message 2 of 5
Re: Extending Wifi signal to garage
doesn't have to be the same make, though you would need to give it it's own ethernet feed
https://www.amazon.co.uk/Tenda-PH5-Powerline-Extender-Streaming/dp/B0746HVPMC/ref=sr_1_3?ie=UTF8&qid...
Click to learn more about VIP
Use Kudos to say thanks
  • 4.98K
  • 350
  • 846
Roger_Gooner
Superstar
Message 3 of 5
Best by far is an Ethernet cable. Use external cable if the garage is detached.
Powerline is second best, might work well or badly, you won't know until you try. One option is this denovo with WiFi.
https://www.amazon.co.uk/Devolo-Powerline-Starter-Adapter-Extender/dp/B00OZDO8RE/ref=sr_1_1_sspa?s=c...
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
service1920
Message 4 of 5
Thank you for your prompt response. So do you mean by "ethernet feed" that I would have to use one of the LAN ports on the router to "create" another WLAN in the house (specific to the garage WLAN) and then use the Wifi adapter in the garage as its access point ?
Essentially the same set up as the powerline I have now but an additional one ?
  • 4.98K
  • 350
  • 846
Roger_Gooner
Superstar
Message 5 of 5
Yes, you would extend your LAN to the garage by using another electrical circuit.
BTW, you don't have to use Powerline WiFi as you can install regular adapters and connect a wireless access point in the garage (good option if you prefer a particular WAP product).
