Foxtrot_Ozcar
Message 1 of 5
Extended Ethernet cable cat6a or7
I'm looking to run a network cable from my V6 box about 80m out to a garden building to run PlayStation streaming. Would Cat6a be ok or Cat7 be better?
tehwolf
  • 1.57K
  • 253
  • 379
Superfast
Message 2 of 5
Re: Extended Ethernet cable cat6a or7
Either should be fine, just make sure it’s outdoor rated. Also, anecdotal reports from this forum suggest that the hub doesn’t like long ethernet runs, so be prepared to buy a cheap switch too 😉
paultechy
  • 19.71K
  • 1.73K
  • 4.32K
Message 3 of 5
doubt you would need 100gbps that cat7 can do, I would stick with cat6 and would only need to go cat6a if need 10gpbs
  • 7.94K
  • 636
  • 1.38K
Message 4 of 5
Agreed, Cat6 will be fine, but I would install two cables for redundancy purposes. The cable itself is extremely cheap and having to do all the work again in the future could cost a lot. When I flood wired my house I made sure every room had 4 cables to it from the patch panel using 2 diverse routes.
apcyberax
  • 33.39K
  • 1.87K
  • 5.94K
Message 5 of 5
good advice here so i'll add a pointless post as we all know what you meant but...
I'd connect it to the Hub not the V6 box 😛
