  • 12
Message 11 of 14
Re: Ethernet switch dropping connection with Hub 3.0
@paul307130 - What was the solution in the end? I am having exactly the same issue and have a similar setup.
  • 15.16K
  • 641
  • 1.47K
Message 12 of 14
Likely they got a router and use the hub in modem mode.
  • 12
Message 13 of 14
@legacy1
Thanks - what's your setup? Looking for a router that works...been having these issues for too long so looking for something that works!
  • 15.16K
  • 641
  • 1.47K
Message 14 of 14
Lots of routers and managed switches depends on how fast you want to go I have a Zyxel USG60W which can do 400Mb TCP you can get at amazon for £250. Then for my main QoS router I have a Zyxel VPN300 that can do 1Gb TCP.
You could look at the Zyxel VPN2S which does hardware offloading so you get 1Gb TCP a odd bug thats being looked into is port 80 is limited to 500Mb but other ports like 443 go at 1Gb. But you need a wireless AP to go with it.
