Ethernet connections not working
We've been having issues with our broadband for a while and in the end, Virgin sent us out a new hub, we set it up and the Wi-Fi seemed to be okay. The ethernet cables worked for a short while but then just disconnected and now we have no connection via ethernet. We have tried on multiple devices but no luck.
We have called Virgin around 20 times over the last 3 days and still have had no resolution.
Please help!
Tags (2)
  • 881
  • 47
  • 108
Superfast
Re: Ethernet connections not working
have you tried a factory reset of the hub?
My Broadband Ping - spgray
Yes this has been tried multiple times
  • 881
  • 47
  • 108
Superfast
you didn't mention that you had in your opening post, hence why asking.
can you disclose what else you have tried so that we don't waste time asking questions.
Tried the hard reset
Turning on and off again
Variety of different ethernet leads and have tried all the ethernet ports on the device
Variety of devices - laptop, booster, xbox
Think that's everything
  • 2.29K
  • 139
  • 178
Hi tmahoney,
Thanks for your post and welcome 🙂
I'm sorry you've had problems with your broadband disconnecting. I can appreciate you'd like to get this working as soon as possible.
It sounds like you've tried most of the diagnostics we'd advise, however I've been unable to locate your account to check your services.
It's been a while since you've posted, so I'm hoping this has now been resolved. However if it hasn't, then please pop me a private message and I'll be happy to help.
Melissa
