  • 10
Message 1 of 10
Ethernet connection disconnects
Hi support,
I work form home and the work pc is plugged with the Ethernet connection. it's been disconnecting for months - it was not big deal until now but I'm soon changing work and need to have a proper connection.
I could be wrong but it seems it disconnects when my housemates connect to the Wifi.
I did reset the hub yesterday, changed the password twice and it keeps happening.
Below are the info available:
Super Hub Version
Software Version   "V2.01.15"
Hardware Version   1.03
Any help would be greatly appreciated,
Thank you
  • 24.72K
  • 1.43K
  • 3.15K
Message 2 of 10
Re: Ethernet connection disconnects
Post the network, upstream and downstream logs from the hubs admin pages
  • 10
Message 3 of 10
Thanks for your reply -
Apologies, im not sure about where to find this data - is it in advanced settings? I'll post it as soon as I locate this. Thanks again
  • 10
Message 4 of 10
 That's what I can see in the advanced settings - I looked in each submenus but I'm not sure about where to find the required info.
Thank you,
  • 10
Message 5 of 10
In terms of network logs, this is all I can see:
  • 24.72K
  • 1.43K
  • 3.15K
Message 6 of 10
  • 10
Message 7 of 10
 ok, thank you for your patience and for your help - just uploaded the pic here -
  • 10
Message 8 of 10
They are still checking the image: I paste/copy the data so:
Downstream ChannelsLock Status Channel ID Frequency Modulation Rx Power RxMER Pre RS Errors Post RS Errors
Locked1139000000 Hz256 QAM-2.3 dBmV 37.1 dB7037294
Locked2147000000 Hz256 QAM-2.2 dBmV 37.4 dB3983312
Locked3155000000 Hz256 QAM-2.3 dBmV 37.4 dB561294
Locked4163000000 Hz256 QAM-2.8 dBmV 37.1 dB893292
Locked5171000000 Hz256 QAM-2.5 dBmV 37.9 dB59645899
Locked6179000000 Hz256 QAM-2.9 dBmV 37.9 dB312303
Locked7187000000 Hz256 QAM-2.8 dBmV 37.9 dB312311
Locked8195000000 Hz256 QAM-2.8 dBmV 37.9 dB299298
To reset the Pre and Post RS error counts please use the Downstream screen under the router status screen available from the login page.
Upstream ChannelsLock Status Channel ID Frequency Modulation Tx Power Mode Channel Bandwidth Symbol Rate
Locked253700000 HzATDMA43.0 dBmV64QAM6400000 Hz5120 Ksym/sec
Locked439400000 HzATDMA43.8 dBmV64QAM6400000 Hz5120 Ksym/sec
Locked346200000 HzATDMA43.0 dBmV64QAM6400000 Hz5120 Ksym/sec
Locked160300000 HzATDMA42.5 dBmV64QAM6400000 Hz5120 Ksym/sec
  • 17.41K
  • 1.83K
  • 3.03K
Message 9 of 10
That looks like an old Superhub1 - should only be used as a doorstop these days. Get it swapped for free as soon as.
try the "free" SH1/2/2ac upgrade/replacement scheme - see the link below - as they are trying to get everyone onto Hub3's.
It works first time for about 50% of customers, but if you get the - "Ooops - please call" message, that usually means you are on an old package that the computer cant recognise so they want to speak to you about it. When you call it in it's a coin toss whether the agent knows about the scheme. If they do they will just say "ok we will send one out" - or - they say "oh no, that's an upgrade there will be a charge and it starts a new contract". Neither of those statements in correct - so just say no thanks and leave the call.
After that you could try texting on 07533 051809 - include account name/number and what the issue is and see what they say – replies may take a bit longer
Finally a VM person should pick this up here and sort the swap for you, but it can take several days.
https://www.virginmedia.com/shop/hub-swap.html?buspart=uk_app_connect2_hubswap
  • 10
Message 10 of 10
Thank you John, just texted the user you provided - fingers crossed! many thanks for your help -
