  • 9
Message 11 of 15
Re: Ethernet connected Broadband keeps dropping out
12990000003.238256 qam21
2139000000438256 qam1
31470000004.138256 qam2
41550000004.338256 qam3
51630000004.138256 qam4
61710000004.538256 qam5
71790000004.538256 qam6
81870000004.638256 qam7
91950000004.540256 qam8
102030000004.338256 qam9
112110000004.438256 qam10
12219000000440256 qam11
13227000000438256 qam12
14235000000438256 qam13
152430000003.738256 qam14
162510000003.540256 qam15
172590000003.540256 qam16
182670000003.440256 qam17
19275000000340256 qam18
20283000000340256 qam19
212910000003.238256 qam20
223070000003.240256 qam22
233150000003.440256 qam23
243230000003.238256 qam24
1Locked38.9170
2Locked38.660
3Locked38.950
4Locked38.970
5Locked38.960
6Locked38.970
7Locked38.9170
8Locked38.6210
9Locked40.3190
10Locked38.970
11Locked38.970
12Locked40.360
13Locked38.650
14Locked38.970
15Locked38.980
16Locked40.370
17Locked40.360
18Locked40.380
19Locked40.350
20Locked40.350
21Locked38.970
22Locked40.390
23Locked40.350
24Locked38.960
  • 9
Message 12 of 15
1326000003.45512064 qam13
2393999863.45512064 qam12
3462000293.45512064 qam11
4537000213.6512064 qam10
3ATDMA0000
4ATDMA0000
  • 9
Message 13 of 15
29/06/2020 21:29:47noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/06/2020 11:55:11criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/06/2020 02:25:11noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxl20016u+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/06/2020 02:25:11ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/06/2020 00:42:30ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/06/2020 23:29:42criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/06/2020 23:02:48ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/06/2020 05:56:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/06/2020 16:17:58noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 02:38:50criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 21:20:59noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 18:40:52noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxl20016u+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 18:40:52ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 13:00:2ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2020 11:58:53criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/06/2020 19:57:47ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/06/2020 14:25:31criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/06/2020 17:22:59noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/06/2020 16:07:38criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/06/2020 08:40:5noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxl20016u+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 9
Message 14 of 15
I assume this this is what you mean? Apologies if not but these are the only upstream/downstream and logs that I can see.
  • 15.44K
  • 1.62K
  • 2.64K
Message 15 of 15
Yes thats them ! Look ok to me.
Can you set up a free “Broadband Quality Monitor” to continually monitor the state of your connection and record any true network dropouts - it will thus allow you to differentiate between those and simple wifi dropouts. It does it 24/7/365 and it keeps a visual record of any/all of your network disconnections, useful data to have to match to the Network logs (in your Hub settings) and also in discussions with VM - note it will take a few hours to start seeing a sensible picture.
