nellystew
  • 6
Ethernet cable length in modem mode
I run a SH3 in modem mode and want to move my router to somewhere else.
Is there a limit on how long the ethernet cable between the SH3 and the router should be?
(it's probably going to be around 10 to 15m)
Thanks.
  • 1.8K
  • 112
  • 413
Super solver
Re: Ethernet cable length in modem mode
The limit is 100 meters or 328 feet for a segment of network cable.
Order a decent cable say CAT6A and you will be fine.
  • 35.06K
  • 3.41K
  • 6.67K
I believe 100m is often quoted... 10-15m is certainly no problem. Look for Cat6a cable as it has better shielding against crosstalk and interference no point in Cat7/8
  • 20.45K
  • 828
  • 2.2K
If your going to move the router away from the hub I would suggest two Ethernet runs
