bell127
Ethernet cable connect not working wifi working
Hi there we are having issues with anything connected to our Hub3 by cable. Wifi is fine but nothing works via cable connection....
The hub is really old but after 3 calls to virgin they insist its not a hub issue.
We have got new cables and still nothing works.....any ideas pls
  • 13.91K
  • 1.08K
  • 2.82K
Re: Ethernet cable connect not working wifi working
I presume you mean Ethernet cable connected devices. You could try a pin-hole reset of the hub, but be aware any configuration changes you have made to the hub will be lost.
bell127
Yes sorry, thats correct anything Ethernet cable connected devices.
I did that reset and still nothing. Told virgin we had done that and still they say its not the hub
Ilyas_Y
  • 2.48K
  • 86
  • 218
Hi there @bell127, thanks for reaching out to us and a warm welcome to the Virgin Media forums 👋
I'm sorry to hear about the issues with the connection you are experiencing.
I've had a look and I can see you have an engineers appointment booked soon.
Let us know how it goes with the appointment and we can go on from there.
Kind regards,
Ilyas.
Ilyas - Forum Team
