on 01-01-2022 19:00
Watching Netflix this afternoon - it suddenly failed. Turns out all wired devices (3 out of 4 ports) to our Hub3 suddenly have no connectivity.
WiFi continues to work just fine.
I have now done a factory reset, recycled the power several times, plugged and re-plugged the cables, changed cables all to no avail.
Have tried to contact VM to ask for a replacement router, but their chat is super-useless, and the phone cuts me off because it claims my 'security number' is wrong.
I'm not really sure what to do now?
on 01-01-2022 19:05
wait for staff to get to the thread is best option - try another reset - they can be iffy - hold the button a good 30sec and add a bit - dont guess time it
on 01-01-2022 20:23
Thank you -
The first time, I held the reset button down for 60 seconds with LAN cables all unplugged, but power on.
Will doing it again make any difference?
on 01-01-2022 21:00
@Jammy192 wrote:Thank you -
theres all sorts of theories on a full reset - i just press the button and wait for the lights to flash - that works most of the time
others say to remove cables - turn power off - stand on one leg etc - its certainly true that it can be difficult and its not consistent - so its really up to you - if you are confident the reset has happened and the lan ports still are not working then you need a new hub imo
on 02-01-2022 11:12
Thanks again.
Yep - I'm convinced that the reset has happened, primarily because the password etc went back to the factory settings.
Presumably it this hadn't happened then the reset wouldn't have been effective - but it did.
on 04-01-2022 11:28
Hi Jammy192
Thanks for posting. Has another reset been done? Let us know if so and if not fixed. Best,
on 04-01-2022 11:43
Yes, tried factory resets 3 times now to no avail. Same response on reset. Wifi working fine - all ethernet ports not connecting. My wired devices report - 'no cable connected'.
on 06-01-2022 11:51
Hello @Jammy192,
Thank you for the update.
I can not see any issues from our side, I do see that you have many devices connected to your Wi-Fi and the speed package you are on will struggle with this many devices. Also Have you tried getting a new Ethernet cable? Or checked that there is no damage to it?
Many thanks,
on 08-01-2022 12:25
Hi Hayley
Firstly - the number of devices we have not 'struggled' with our current speed package at all - ever.
As I've made clear previously, the problem I'm detailing affects *all* wired ethernet ports from your router (not just one).
Yes I've changed cables (because you always ask), but that's a non-sensical thing to do if ALL of the ports fail at the same time.
I say again - wifi works fine. The ethernet / lan ports do not work......
Isn't it clear that this is a router problem?
on 10-01-2022 12:48
Hi Jammy192,
I'm sorry to see that the issue still persists.
From looking at it today it does state that two devices are connected via Ethernet currently, has the issue rectified itself.
Also I can see you raised a complaint regarding this issue, our team have attempted to contact you, has a call back been successful?
Let us know,
