RangerMerley
  • 6
Message 1 of 11
Ethernet Ports Hub 3
Good Day/Evening/Night
Seem to be having an issues with the Lan speed.
All Cat 5 Cables 1gb network and cards, have checked by plugging laptop directly...however only getting ethernet port speeds of between 50-60mps. Wifi is getting around 300mps. We are on the 600plan.
1. Are for ports limited (would be odd)?
2. A setting I'm missing
Looking forward to hearing from you.
Cheers in advance or not!!! 🙂
Tags (3)
  • 2.94K
  • 224
  • 629
Trouble shooter
Message 2 of 11
Re: Ethernet Ports Hub 3
Gigabit needs Cat5e or better to get gigabit speeds.  Cat 5 is limited to 10/100 mb.
  • 8.15K
  • 650
  • 1.43K
Message 3 of 11
If they are Cat5 cables with all 4 pairs wired they should get higher than the speed you get. The Cat5 specification may say only 100M, but when written this only involved using 2 pairs of the four. Cat5 cables with a 4 pairs will, in most circumstances give you 1G ok. I have some long drops of AT&T high quality Cat5 cables that are years old and still give 1G all the time. Cat5e will certainly give you 1G, although I have seen many faulty Cat5e cables where one of the wires is broken/not connected correctly and they were working at 100M. There is a lot of difference between specification and real world use.
lotharmat
  • 966
  • 71
  • 145
Well-informed
Message 4 of 11
First thing I would do is swap out any cables - remove that from the equation as a potential problem!
RangerMerley
  • 6
Message 5 of 11
Replaced all the cables today CAT6...no change
RangerMerley
  • 6
Message 6 of 11
RangerMerley
  • 6
Message 7 of 11
Hi Update
  • Bought new cables
  • Tried Mac
  • Tried PC
  • Tried Laptop
  • Tried ChromeBook
The ethernet ports are only getting speed readings between 60-70 max.
any other ideas, looks to me if they are capped or faulty
  • 15.94K
  • 691
  • 1.56K
Message 8 of 11
Put hub in modem mode and do a speed test with cmd running ping -t 194.168.4.100
RangerMerley
  • 6
Message 9 of 11
Router crashes and red lights when switched to Modem mode.
Had to reset
  • 15.94K
  • 691
  • 1.56K
Message 10 of 11
Guess you need a new hub 3
