Ethernet PCs Not Seen On Home Network
my-generation
In connection with this problem I ran the network diagnostics tool on my hub 3.0
It came back with "gateway ipv4 address is invalid"
How do I fix this please?
4 REPLIES 4
Is that a complaint about the Gateway address of the VM Hub 3 or the PCs ?
For a Hub in Router mode, the PCs etc should use Gateway address 192.168.0.1 ( the IP of the Hub )
For our Hub 3 the WAN Gateway is [REMOVED]  & is seen at Hub 3 menu >>> Admin >>> Info
Looking at the Hub 3 >>> Connected devices, static IP devices and Reserved addresses below the DHCP range are not listed.  All of our devices with  regular DHCP IP from the Hub 3 are present in the Connected devices list.
[MOD EDIT: Personal and private information has been removed from this post. Please do not post personal or private information in your public posts. Please review the Forum Guidelines]
my-generation
It's simply a question asking how can I fix a  "gateway ipv4 address is invalid" message which the hub tells me following using the network diagnostic tool
Roger_Gooner
Do you have a broadband problem.
Hub 5, TP-Link TL-SG108S 8-port gigabit switch, 360
My Broadband Ping - Roger's VM hub 5 broadband connection
my-generation
No, but I have since found that uninstalling the ethernet network adaptor when shutting down ensures that it works when next boot up. Strange.
