salkhan1409
  • 17
Message 1 of 24
Ethernet Connection to Virgin 3.0
Hi I am unable to get my MAC to connect to the hub via cable. Do Virgin supply the IP address? The MAC response seems to suggest it should. Any ideas will be gratefully received.
Sal
Ernie_C
  • 18.56K
  • 2.04K
  • 4.58K
Message 2 of 24
Re: Ethernet Connection to Virgin 3.0
You asked this before. What’s different?
https://community.virginmedia.com/t5/Networking-and-WiFi/iMac-Ethernet-IP-address-issue/m-p/4454439
salkhan1409
  • 17
Message 3 of 24
I gave up with the BT wifi. However I still cannot connect to the Internet through an ethernet cable. I've tried all 4 connections - doesn't work. Does Virgin assign an IP address?
NinjaMeerkat
  • 267
  • 15
  • 51
Fibre optic
Message 4 of 24
Is the hub now in router mode? If so the hub will provide IP addresses to connected devices.
salkhan1409
  • 17
Message 5 of 24
thank you, the message I receive is "Ethernet has a self-assigned IP address and will not be able to connect to the internet." Does that ring any bells?
salkhan1409
  • 17
Message 6 of 24
thank you. the message I get is "Ethernet has a self-assigned IP address and will not be able to connect to the internet." Does that ring any bells?
NinjaMeerkat
  • 267
  • 15
  • 51
Fibre optic
Message 7 of 24
Sounds like the device you are using has a static IP address configured. You need to go into network settings and in the ethernet properties change the option to allow dhcp addresses.
Roger_Gooner
  • 6.73K
  • 490
  • 1.19K
Legend
Message 8 of 24
Have you configured the Network's IPv4 to use DHCP?
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG108S 8-port gigabit switch, V6
salkhan1409
  • 17
Message 9 of 24
thank you, from what I can see that's been done,
salkhan1409
  • 17
Message 10 of 24
thank you, yes it is configured.
