Errors in my hub 5 logs
Sparkyst
HI Guys
I am getting these errors in my hub 5 logs, anything to be concerned about?
25-07-2023 23:16:13noticeREGISTRATION COMPLETE - Waiting for Operational status
25-07-2023 23:16:07noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
25-07-2023 23:15:54warningDHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
25-07-2023 23:15:52noticeHonoring MDD; IP provisioning mode = IPv4
25-07-2023 23:15:45criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
25-07-2023 23:15:34criticalCable Modem Reboot due to power button reset
25-07-2023 23:08:44criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
25-07-2023 23:08:32criticalCable Modem reboot from UI
25-07-2023 23:02:35criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
25-07-2023 23:02:13criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
25-07-2023 23:02:07criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
25-07-2023 23:02:05criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
25-07-2023 22:41:35criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
25-07-2023 22:41:30criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
25-07-2023 22:41:18criticalCable Modem tr069-reboot
24-07-2023 22:34:09criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
24-07-2023 22:33:57criticalCable Modem Reboot via RG reboot command
24-07-2023 22:30:22criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
24-07-2023 22:30:17criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
24-07-2023 22:30:00criticalCable Modem reboot from UI
22-07-2023 09:35:38criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
18-07-2023 22:57:32criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
18-07-2023 22:57:27criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
5 REPLIES 5
carl_pearce
Community elder
There are planned outages, which one recently happened for me, that you can check for:
https://www.virginmedia.com/support/help/service-status
Having said that they usually occur early hours.
You HUB rebooted a couple of times in a short peroid. Some of those times I assume was you I assume as once was a 'Cable Modem reboot from UI', and the other 'Cable Modem Reboot due to power button reset'?
Sparkyst
yes I was rebooting it try to clear the errors, have an engineer coming Saturday to check everything as more errors and timeouts are appearing
The errors are recorded historically so will not clear for a period of time.
Sparkyst
Sorry I meant I was rebooting it to see if the errors would stop. But they didnt
Hi Sparkyst,
Thank you for your post and welcome to the community.
We're sorry to hear about the issues you've had with your service.
We're glad to hear you've got an engineer booked in.
If you need any assistance after the visit, please do reach out to us on here.
^Martin
