Jmg3
Erratic wifi
We have a hub 3 with around 10-15 devices connecting to it.  The signal is strong in every room of the house.  Generally the wifi signal works very well but there are also long periods when the signal is very weak and devices struggle to connect.  We are contemplating upgrading our broadband speed but reluctant to do so if the signal is similarly erratic and this doesn’t solve our issues.
tehwolf
  • 1.62K
  • 263
  • 393
Superfast
Re: Erratic wifi
upgrading the speed of your connection will have no impact on the quality of your wifi signal.
do you have any ethernet-connected devices and do they work well?  If so, you may want to consider buying yourself a decent router and putting the hub into modem mode.
