SaintRob
Erratic Wifi
Hi Everyone
I've recently moved from a flat to a small house and having fun trying to use the wifi in the room that I use as a home office. If you were to look at the diagram provided on this forum it would be room 3 that has a couple of walls and a floor between it and the router. I figured I would never get anything like the full 100meg in the room but would be quite happy with around 20 or so. Thing is its really eratic in that room going from 80-0.02 seemingly with nothing changing in a few seconds. I dont really understand why it would change so much and am wondering if anyone would be kind enough to share some advise as to how to help it be more consistent?
PS I used the virgin media connect app and it says a "great" signal in that room even when was getting less than 1 meg. I am not very technical so didnt want to start changing channels or messing with the ghz in fear of making it worse.
Thanks in advance for any help!
Tags (1)
Anonymous
Not applicable
Re: Erratic Wifi
get your own router or mesh system
