Donald1946
  • 30
Equipment
Hi does the engineer bring your equipment when the install date is reached ?
lotharmat
  • 2.54K
  • 189
  • 462
Trouble shooter
Re: Equipment
Should do!
Hub, cabling and connectors - unless you've opted for a quick-start - in which you should just be able to connect the hub to the socket with the provided cable, activate if necessary and you're away!
Paulina_Z
  • 1.07K
  • 33
  • 69
Re: Equipment
Hi @Donald1946,
Welcome back to  our Community Forum. Thank you for reaching out and for posting.
As @lotharmat suggested, unless you have opted out for our QuickStart Install option, the technician will bring all of the equipment needed to install your services.
Please keep us updated on how your visit goes and let us know if there's anything else we can do to help.
Thanks! 🙂
Paulina_Z
Donald1946
  • 30
Re: Equipment
Engineer will be installing had i had the Virgin Media points could have done it myself as i did when i was with BT just a case of connecting up cables etc.
Paulina_Z
  • 1.07K
  • 33
  • 69
Re: Equipment
Hi @Donald1946,
If the option for a QuickStart Install was available to you, you would have been able to install the services yourself.
However, sometimes this option is not available as our technicians have to ensure that all correct cables are already in place at the property.
I'm sure the engineer visiting will be able to have everything sorted out for you. Please keep us updated on how you get on.
Thanks! 🙂
Paulina_Z
Paulina_Z
  • 1.07K
  • 33
  • 69
Re: Equipment
Hi @Snowmantis,
Welcome to our Community Forums! Thanks for your first post and for such kind words! 🙂
You're more than welcome to post any issues or concerns you're having with our service, our team is more than happy to help.
Thanks! 🙂
Paulina_Z
