Treble1
  • 397
  • 5
  • 85
Fibre optic
Message 1 of 16
Eero pro 6 3 pack
If the hub 4 is in modem mode with the eero pro 6 can I still use the hub 4 Ethernet ports or is only one available thanks
Ernie_C
  • 19.72K
  • 2.17K
  • 5.07K
Message 2 of 16
Re: Eero pro 6 3 pack
All Virgin Media Hubs in Modem Mode only have a single Ethernet port active. They become a modem, no router function.
Andrew-G
  • 10.4K
  • 1.66K
  • 4.75K
Message 3 of 16
Only one will work.  If more than one thing is plugged in, the hub will connect the first one it recognises, and then ignore anything else.  If you need more ethernet ports, then the best way is usually to connect a fifteen pound "unmanaged gigabit ethernet switch" to the spare ethernet socket on the master Eero unit.
Treble1
  • 397
  • 5
  • 85
Fibre optic
Message 4 of 16
Thanks just picked up a 3 pack eero pro 6 £290 del will order a switch of Amazon as well
Akua_A
  • 4.08K
  • 105
  • 283
Message 5 of 16
Hi @Treble1,
Welcome back to our community forums and thank you for your query regarding Eero pro 6 3 pack.
We are glad to see that @Ernie_C and @Andrew-G have been able to help regarding this. Please do not hesitate to contact us if you need any further help.
Akua_A
Treble1
  • 397
  • 5
  • 85
Fibre optic
Message 6 of 16
Been at it all day I can get them connected in router mode ,but not a chance modem mode I have set the hub up direct via Ethernet to a laptop,it shows as  modem mode but no joy does anybody else have his set up cheers
Ernie_C
  • 19.72K
  • 2.17K
  • 5.07K
Message 7 of 16
Given you have proved that the Virgin Media Hub goes into Modem Mode, you’d be better seeking support from eero support.
https://support.eero.com/hc/en-us/articles/360057257791-Setting-Up-eero-with-Virgin-Media
  • 12.88K
  • 1K
  • 2.57K
Message 8 of 16
You must turn off the VM hub once it’s in modem mode. Then power up and fully initialise the Eero and finally turn on the VM hub.
Stobbsy74
  • 163
  • 44
Superfast
Message 9 of 16
Yes this, took me a while to figure this out on my system. Any of the ethernet ports can be used, but for the hub to know which 1 is being used in modem mode, the router that is connected to it needs to be powered on and then the hub turned on.
When its on you cant swap ports as they are disabled, only the ones that are active on boot up stay active.
Treble1
  • 397
  • 5
  • 85
Fibre optic
Message 10 of 16
Thanks will try again this afternoon with a few Peronis merry Xmas all
