Message 1 of 7
Eero Mesh and Virgin Hub
Is it possible to plug the Eero Mesh system into the Virgin Hub, rather than using the Virgin hub as a modem only?   In effect having two WiFi systems running?
I want to use the Eero for my work - my office is at the far end of the house away from my Virgin box - and I don’t want to disrupt anything that’s already running on the Virgin hub (Nintendo/Sonos/PS4 etc).  It will just be my laptops for work.
  • 11.58K
  • 828
  • 1.64K
Message 2 of 7
Re: Eero Mesh and Virgin Hub
Yes, if you just plug in the mesh to the hub in router mode you will achieve this
I work for Virgin Media and my posts are my own opinions
  • 24.97K
  • 1.44K
  • 3.18K
Message 3 of 7
Why would you want to do that? The Eero nodes should provide you with better coverage than the hub will alone.
  • 24.97K
  • 1.44K
  • 3.18K
Message 4 of 7
Not really. If the Eero is also set to run as a router you’ll get issues with Double NAT and DHCP issues etc leading to dropouts.
Message 5 of 7
To be frank, I just want to plug it in and go.  All the family stuff is on the Virgin hub and I don’t want to mess any of it up.
  • 24.97K
  • 1.44K
  • 3.18K
Message 6 of 7
You can give the Eero the same Wi-Fi SSID and Password that you’re currently using with the hub
  • 11.58K
  • 828
  • 1.64K
Message 7 of 7
gary_dexter, Eero can be put in Bridge mode like most mesh systems can.  I would agree with gary though as you've spent good money on a decent piece of kit, you may as well use modem mode
