on 28-08-2022 08:55
I have the same problem. Solution has not worked for me. Any other help or suggestions?
Answered! Go to Answer
on 10-09-2022 19:25
Now Web Safe is turned off, all working great.
on 03-03-2023 15:24
i have this issue and my online security is all turned off and always has been since I got Virgin, verified even toggled for safe measures.
eero still won’t connect
any other thoughts?
03-03-2023 15:59 - edited 03-03-2023 16:00
Change eero DNS to use 1.1.1.1, 8.8.8.8 or 9.9.9.9 might not work if the problem is what I think it is and you need to talk to the makers of eero
on 03-03-2023 17:07
Turned out to be the VM we safe spam filters was blocking eeros connecting.
beware of these settings:
https://my.virginmedia.com/my-apps/onlinesecurity/websafe/settings
on 05-03-2023 22:02
on 05-09-2023 09:27
Dropped into this thread for help.
Trying to get the Eero 6+ to work with VM Hub3. No luck, persistent issue is that I get the following:
Can confirm that the VM Hub3 is in modem mode (I can access it via a cable on 192.168.100.1) and can then reset it back to Router mode. Each time I switch to modem mode, I ensure that only the Eero 6+ is the only device connected to Lan port 1 on the Hub 3.
I have used a different Eero 6+ hub as a test; each one fails with the same exact issue.
Am getting increasingly convinced there is some compatibility issue with the Eero 6+ and the VM Hub 3. Am not rushing this either: spent the entire weekend working on this. Switching off the devices for 5-10 minutes at a time to ensure that nothing is hanging around. Am definitely switching the VM HUB3 into modem mode correctly, can confirm that the LED is magenta when in this mode (and white when back to router/wifi mode).
No issue with connecting to the Eero hub using the app - works fine; just the Eero device(s) can't seem to talk to the Hub 3. It doesn't pick up a new internet facing IP Address. Baffled.
Any ideas (incl. sacrificial offerings) much appreciated.
on 07-09-2023 14:36
Hi WMLEE,
Thanks for taking the time to post in the Community. We're sorry to hear you've been having an issue with getting your EERO router set up to work with the hub.
I can see from previous posts that other users have suggested the following:
➡ disabling the Virgin Media Websafe Settings - Leave Virus Safe on but disable Child Safe. You can do this within My Virgin Media.
Another user also suggested checking settings here.
Please give these a try and let me know if this helps.
Many thanks,
