jaligwekwe
  • 7
Message 1 of 12
Dropping broadband signal
I am currently on OOMPH 350 and in the middle of a zoom meeting or watching tv or WhatsApp call or internet browsing the signal just drops for a few seconds and then comes back , it happens so often it can be quite frustrating . Please any advice is welcome . Is this normal because it seems the higher and supposed better broadband I got the worse the service has become .
jpeg1
  • 4.78K
  • 264
  • 773
Superstar
Message 2 of 12
Re: Dropping broadband signal
Is that with a WiFi or ethernet connection to the Hub?
To check for broadband dropouts, set up a free BQM and post a link here.  https://www.thinkbroadband.com/broadband/monitoring/quality
Zak_M
  • 4.45K
  • 259
  • 421
Message 3 of 12
Good afternoon @jaligwekwe
Welcome to the forums and thank you for taking the time to post.
I am sorry to hear that you have had some issues with your services.
How are things looking since your post? Have there been any improvements?  Did you manage to set up a BQM as previously advised?
Kind regards,
Zak_M
jaligwekwe
  • 7
Message 4 of 12
No I still haven’t sorted it out . It’s quite frustrating. For example I am sending this message with my mobile data because as I was typing it started dropping on and off so I switched to data . Please help. I am paying so much because my business  is virtual sometimes in the middle of a zoom meeting I switch to data just to stay stable . I wish I knew how to book an engineer to come and check it out. I am fairly new to virgin so struggling a bit to understand how their service works , unfortunately so far not impressed . I have increased my broadband from 100 to 350 and still no joy. Please do assist if you can .  Thank you .
jaligwekwe
  • 7
Message 5 of 12
It’s with an Ethernet connection to the hub I hope that’s right because I presume you are referring to my connection to the wall socket where the system feeds the house ? Please clarify . Thank you
Zak_M
  • 4.45K
  • 259
  • 421
Message 6 of 12
Good morning @jaligwekwe
Thank you for coming back to me.
I have this morning checked the network in the local area and everything seems clean as a whistle,  please can you set up the BQM as requested in post number 2.
Kind regards,
Zak_M
lotharmat
  • 2.54K
  • 188
  • 462
Trouble shooter
Message 7 of 12
How is the device that you are using connected to your network?
Is there a cable running from your device (laptop etc) to the Hub or are you connected with WiFi?
jaligwekwe
  • 7
Message 8 of 12
My devices are all connected via WiFi I don’t have any devices connected directly to the hub . Thank you for clarifying.
jaligwekwe
  • 7
Message 9 of 12
Thank you will attempt the BQM .
jaligwekwe
  • 7
Message 10 of 12
Please find attached a result for a BQM test done hope this can help . https://www.thinkbroadband.com/speedtest/1625997786477464055
