10-10-2023 09:57 - edited 10-10-2023 10:12
Why do I have to reset my hub 4 every week and every day after it’s been raining, I’m getting so annoyed now and can I get through to someone in tech…..NO you get the robot every time, I did get through to someone and he was so rude that he didn’t believe me even when I was quoting the error codes on the TV.
Im so disappointed to what used to be a good service till the service robot got involved!
on 10-10-2023 13:40
Can you do this.....
Post up your Hub/network connection details and someone will check to see if there is a problem there. In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
on 10-10-2023 13:46
25 | 330750000 | 7.500000 | 40.366287 | QAM256 | 25 |
18 | 274750000 | 6.300003 | 40.946209 | QAM256 | 18 |
19 | 282750000 | 6.099998 | 40.366287 | QAM256 | 19 |
20 | 290750000 | 6.000000 | 40.366287 | QAM256 | 20 |
21 | 298750000 | 5.900002 | 40.946209 | QAM256 | 21 |
22 | 306750000 | 6.300003 | 40.366287 | QAM256 | 22 |
23 | 314750000 | 6.699997 | 40.366287 | QAM256 | 23 |
24 | 322750000 | 7.300003 | 40.946209 | QAM256 | 24 |
26 | 338750000 | 7.300003 | 40.946209 | QAM256 | 26 |
27 | 346750000 | 7.500000 | 40.366287 | QAM256 | 27 |
28 | 354750000 | 7.500000 | 40.366287 | QAM256 | 28 |
29 | 362750000 | 6.800003 | 40.366287 | QAM256 | 29 |
30 | 370750000 | 6.900002 | 40.946209 | QAM256 | 30 |
31 | 378750000 | 6.599998 | 40.366287 | QAM256 | 31 |
32 | 386750000 | 6.599998 | 40.366287 | QAM256 | 32 |
33 | 394750000 | 5.800003 | 38.983261 | QAM256 | 33 |
34 | 402750000 | 4.800003 | 38.983261 | QAM256 | 34 |
35 | 410750000 | 5.099998 | 40.366287 | QAM256 | 35 |
36 | 418750000 | 5.400002 | 40.946209 | QAM256 | 36 |
37 | 426750000 | 5.800003 | 40.366287 | QAM256 | 37 |
38 | 434750000 | 6.099998 | 40.366287 | QAM256 | 38 |
39 | 442750000 | 6.300003 | 40.366287 | QAM256 | 39 |
40 | 450750000 | 6.300003 | 40.366287 | QAM256 | 40 |
41 | 458750000 | 5.699997 | 38.983261 | QAM256 | 41 |
42 | 466750000 | 6.000000 | 40.366287 | QAM256 | 42 |
43 | 474750000 | 6.199997 | 40.366287 | QAM256 | 43 |
44 | 482750000 | 6.500000 | 40.366287 | QAM256 | 44 |
45 | 490750000 | 6.000000 | 40.366287 | QAM256 | 45 |
46 | 498750000 | 5.500000 | 38.983261 | QAM256 | 46 |
47 | 506750000 | 5.900002 | 40.366287 | QAM256 | 47 |
48 | 514750000 | 6.199997 | 40.366287 | QAM256 | 48 |
25 | Locked | 40.366287 | 0 | 0 |
18 | Locked | 40.946209 | 0 | 0 |
19 | Locked | 40.366287 | 0 | 0 |
20 | Locked | 40.366287 | 0 | 0 |
21 | Locked | 40.946209 | 0 | 0 |
22 | Locked | 40.366287 | 0 | 0 |
23 | Locked | 40.366287 | 0 | 0 |
24 | Locked | 40.946209 | 0 | 0 |
26 | Locked | 40.946209 | 0 | 0 |
27 | Locked | 40.366287 | 0 | 0 |
28 | Locked | 40.366287 | 0 | 0 |
29 | Locked | 40.366287 | 0 | 0 |
30 | Locked | 40.946209 | 0 | 0 |
31 | Locked | 40.366287 | 0 | 0 |
32 | Locked | 40.366287 | 0 | 0 |
33 | Locked | 38.983261 | 0 | 0 |
34 | Locked | 38.983261 | 0 | 0 |
35 | Locked | 40.366287 | 0 | 0 |
36 | Locked | 40.946209 | 0 | 0 |
37 | Locked | 40.366287 | 0 | 0 |
38 | Locked | 40.366287 | 0 | 0 |
39 | Locked | 40.366287 | 0 | 0 |
40 | Locked | 40.366287 | 0 | 0 |
41 | Locked | 38.983261 | 0 | 0 |
42 | Locked | 40.366287 | 0 | 0 |
43 | Locked | 40.366287 | 0 | 0 |
44 | Locked | 40.366287 | 0 | 0 |
45 | Locked | 40.366287 | 0 | 0 |
46 | Locked | 38.983261 | 0 | 0 |
47 | Locked | 40.366287 | 0 | 0 |
48 | Locked | 40.366287 | 0 | 0 |
49 | 96 | 4K | 1840 | QAM256 | 759 |
49 | Locked | 40 | 6.6 | 1525689 | 0 |
on 10-10-2023 13:47
1 | 49600000 | 45.770599 | 5120 KSym/sec | 64QAM | 1 |
2 | 43100000 | 45.270599 | 5120 KSym/sec | 64QAM | 2 |
3 | 30100000 | 45.270599 | 5120 KSym/sec | 64QAM | 4 |
4 | 23600000 | 45.020599 | 5120 KSym/sec | 32QAM | 5 |
5 | 36600000 | 45.270599 | 5120 KSym/sec | 64QAM | 3 |
1 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
2 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
3 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
4 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
5 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
6 | 10.4 | 41.5 | 2K | QAM128 |
6 | OFDMA | 208 | 53.4 | 0 | 0 |
10-10-2023 14:02 - edited 10-10-2023 14:03
Stats look good to me apart from one up channel qam dropping to 32 from 64. This could be indicative of an issue - can you do this...
Switch the Hub off and unplug it from the mains supply for five minutes. Whilst it's off, do a quick check that all of your coax and ethernet cable connections are in nice and "finger" tight - at the Hub and wall box and also at any connectors etc. Ensure there are no “unterminated cable loose ends. Disconnect all the connections and reconnect to be sure. Also check that the internal wiring is ok with no kinking or chaffing. When its light, check that all looks good with the outside cabling and wall box (no “staples, etc.,) piercing the cables. Then switch the Hub back on and leave ~5 minutes When all done, check back in the settings and ensure that the RS error counts and T3 errors have all reset to 0. Then check every hour or so to see if they start reappearing - they shouldn't. If they do (particularly the postRS and T3 ones) you have a problem (noise) that only a Tech visit will sort.
Also check the Upstream QAM’s are all at 64 - if they are still dropping (to 32/16) then see message from sephiroth here…
Also... can you post up the BQM link as soon as.
on 10-10-2023 16:08
1 | 43100000 | 45.270599 | 5120 KSym/sec | 64QAM | 2 |
2 | 49600000 | 45.770599 | 5120 KSym/sec | 64QAM | 1 |
on 10-10-2023 16:08
Hi John I did what you said but I see I still have the upstream problem
on 10-10-2023 17:23
Hi @Sideflow, thank you for your post.
We're sorry to hear about the problems you're experiencing 😔
In order to look into this for you further, we'll send you a private message on here. Look out for the envelope in the top right-hand corner.
Thank you for your support @jbrennand 👍
Regards,
Daniel
on 18-10-2023 08:48
All sorted Thankyou guys, the technician came out and had to replace the hub 4 as it was playing up when he checked the months data stats.
on 20-10-2023 09:57
Hi Sideflow! 👋 Thank you for returning to the thread to keep it updated.
Really pleased to hear the technician resolved things for you.
Please do get back in touch if you have any further issues in future and we will be happy to help. Wishing you all the best! 🌞
