Downstream power levels
JamieB1
Can someone check my downstream and up stream I currently have a forward path attenuator 6db on, when using ps5 I get "the router you are using may not support ip packet fragmentation" with a wiered connection I have tried directly to the HUB5 and through a 3rd party access point neygear WAX 206 AX3200
Sometimes on rare occasions the power levels can spike up to 35dbmv
7 REPLIES 7
JamieB1
this is also with a ethernet upload is between 15mps and 30mbps normally
posting screenshots is no help for ageing eyes 😎 - post as plain text in future
but it looks like your down powers are out of range - the acceptable range is....
+10dBmV to -6dBmV  are yours above the +10?
Yes my downstream are always above 10+ normally they sit at 15+dBmV on very rare occasions they have spiked up to 30± but that hasn't happened in awhile
Then you definitely need a Tech visit to bring them back into mid-range.
A VM person will help here soon
Mr-Hare
I posted in the gaming section about getting the same message on the PS5 speed test recently too.
https://community.virginmedia.com/t5/Gaming-Support/PS5-IP-packet-fragmentation/td-p/5398136
All my hub stats are within spec and I'm not noticing any issues apart from the PS5 speed test now saying the router might not support IP fragmentation when it didn't before.
Steven_L
Hey JamieB1,
Welcome to the community and thanks for taking the time to post here on the forums.
I’m sorry to hear of the issues that you’re having with your connection at the moment. I would be happy to take a further look into this for you but first I would need to confirm a few details via private message, please look out for my message and we can get started.
Kind Regards,
Steven_L
My issue started a few days after I upgraded to 1gig I didn't get the ip packet fragmentation before on speed tests. Only thing I can see that off is the power levels but I need to get a forward path attenuator 15db to try that
