ewan72
Downstream RS. on chanel 23 and 24 post RS are far higher than PRe ,
23Locked37.33561514
24Locked37.66105218
I also have critical errors
  • 35.04K
  • 3.41K
  • 6.66K
Re: Downstream RS. on chanel 23 and 24 post RS are far higher than PRe ,
see this
_______
Switch the Hub off and unplug it from the mains supply for five minutes. Whilst it's off, do a quick check that all of your coax and ethernet cable connections are in nice and "finger" tight - at the Hub and wall box and also at any connectors etc. Ensure there are no “unterminated cable loose ends. Disconnect all the connections and reconnect to be sure. Also check that the internal wiring is ok with no kinking or chaffing, check that all looks good with the outside cabling and wall box (no “staples, etc.,) piercing the cables. Then switch the Hub back on and leave ~5 minutes
When all done, check back in the settings and ensure that the RS error counts and T3 errors have all reset to 0. Then check every hour or so to see if they start reappearing - they shouldn't. If they do (particularly the postRS and T3 ones) you have a problem (noise) that only a Tech visit will sort.
ewan72
I rebooted my  Hub before and all RS,s   were 0, that was about two weeks ago. I will do as you suggested and get back to you.
ewan
