Downstream Post RS Errors
worf105
Hello all,
I have been monitoring my connection over the last few day/weeks and have now become concerned about the Post RS errors that are increasing each day.
Snippet from Log:
13 REPLIES 13
John_GS
Hi @worf105
Are you currently experiencing any service issues? The reason I ask, there's no area outages showing here. Please do let us know if so and we can assist further.
Best wishes.
John_GS
Cheers John,
I Have been monitoring this for another week and the pre and post errors are climbing still.  Now getting some T1 to T4 errors on my uploads. The connection seems stable enough with some blips here and there. The last time I seen these the engineer replaces inside cables and went outside to street and done something with the taps.
When the engineer did those changes did the service improve?
^Martin
worf105
Yes indeed
worf105
Increasing again:
1Locked392970
2Locked374357
3Locked374500
4Locked374500
5Locked374823
6Locked374200
7Locked384050
8Locked384100
9Locked384220
10Locked384300
11Locked384000
12Locked384150
13Locked383890
14Locked383870
15Locked383920
16Locked383700
17Locked383290
18Locked382460
19Locked382220
20Locked382900
21Locked382850
22Locked392830
23Locked392900
24Locked393000
25Locked3930812
26Locked392820
27Locked393295
28Locked3937523
29Locked40295104
30Locked39312164
31Locked3933464
13310000005.139QAM 25625
21390000008.537QAM 2561
31470000008.337QAM 2562
41550000007.837QAM 2563
51630000007.537QAM 2564
61710000007.337QAM 2565
7179000000738QAM 2566
81870000006.938QAM 2567
9195000000738QAM 2568
102030000006.838QAM 2569
112110000006.738QAM 25610
122190000006.438QAM 25611
132270000005.838QAM 25612
142350000005.338QAM 25613
152430000005.138QAM 25614
162510000004.738QAM 25615
172590000004.738QAM 25616
182670000004.638QAM 25617
19275000000538QAM 25618
202830000005.238QAM 25619
212910000005.438QAM 25620
222990000005.439QAM 25621
233070000005.439QAM 25622
243150000005.339QAM 25623
253230000005.239QAM 25624
263390000005.239QAM 25626
273470000004.940QAM 25627
283550000004.839QAM 25628
293630000004.740QAM 25629
303710000004.139QAM 25630
313790000003.839QAM 25631
worf105
04960000038.35120QAM 641
14310000037.35120QAM 642
23660000036.35120QAM 643
33010000034.85120QAM 644
423600000345120QAM 645
0ATDMA0100
1ATDMA0100
2ATDMA0120
3ATDMA0100
4ATDMA01253
worf105
08-09-2023 18:28:04criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
08-09-2023 18:26:35criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
08-09-2023 18:23:45criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
08-09-2023 18:23:20criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
08-09-2023 03:25:50criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
08-09-2023 03:25:38errorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
04-09-2023 15:25:34criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
04-09-2023 15:25:32errorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
03-09-2023 21:52:01criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
03-09-2023 21:51:45warningTCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
03-09-2023 21:51:01criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
03-09-2023 21:50:45warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
03-09-2023 21:37:05criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
03-09-2023 21:36:34warningTCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
03-09-2023 21:35:38criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
03-09-2023 21:35:34warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
03-09-2023 21:22:05criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
03-09-2023 21:21:24warningTCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
03-09-2023 21:20:49criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
03-09-2023 21:20:24warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
03-09-2023 21:05:32criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
03-09-2023 13:59:16noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
03-09-2023 13:59:16warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
03-09-2023 13:49:11noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
03-09-2023 13:49:11warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-09-2023 21:29:17noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-09-2023 21:29:17warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-09-2023 21:19:13noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-09-2023 21:19:13warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-09-2023 13:35:23noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-09-2023 13:35:23warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-09-2023 12:27:23warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
worf105
Any help will be appreciated.
Hey worf105, thank you for reaching out and I am sorry to see you are having some connection issues.
I have taken a look and I can see there are some short term connection issues which should of been resolved by now over the weekend.
How has the connection been, has it improved? Cheers
Matt - Forum Team
New around here?
