Down stream power fluctuating
Hi all,
I have all of a sudden started to suffer with the hub locking up, then taking several reboots to come back online. Once back on line I have checked the log and upstream power which seems to vary from -3db to -20db and fluctuate constantly. I've checked all the connections and these appear tight, any other suggestions would be appriciated.
  • 17.57K
  • 1.85K
  • 3.06K
Re: Down stream power fluctuating
Its nearly impossible to see the data and some of it hasnt been approved - it must contain i.p./MAC addresses.
So can you post it again this way....
Copy/paste as “Formatted Text” (not images) 3 FULL sets of data onto here – 2 pages from the Downstream, 2 from the Upstream, & the Network Logs page. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you. If you get an error message just need to click the "submit" button again - or split the data into 2 posts.
Thanks, looks like we have an engineer on the way now to investigate
