leejt1978
Does my tivo box wifi run 24Ghz
I’ve recently purchased a smart floor lamp and downloaded the smart life app which controls it which runs on 2.4Ghz imput. How do I set this up on my TiVo box
gary_dexter
  • 30.49K
  • 1.89K
  • 4.05K
Re: Does my tivo box wifi run 24Ghz
TiVo is a TV set top box and has nothing to do with smart lighting
g0akc
  • 886
  • 82
  • 170
Well-informed
Run the smart life app and follow the instructions to set up the lamp using the 2.4GHz Wi-Fi from your router/hub.
The TiVo TV box has nothing to do with it.
I know a bit about Wi-Fi, Telecoms, and TV as I used to do it for a living but I'm not perfect so don't beat me up... If you make things you make mistakes!
